- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Orbi support of SMB2
- Mark as New
- Bookmark
- Subscribe
- Permalink
I just updated the firmware to 2.3.1.60 but I am still unable to acces shared folder from windows PC on an android device. When I attempt to it says that SMB 2.0 in needed and needs to be unlocked. I verified SMB 2.0 is supported on the PC. Someone else said that the turned uPnP on/off and that solved the problem for them but it did nothing for my. Does Orbi support SMB2, and if not when are you going to get around to supporting it?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi support of SMB2
SMB is only a pass thru on the Orbi. SMB needs to be supported on the client side.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
You would need to contact the Mfr of this device and ask them about SMB support.
I presume that if you share out a folder on one PC and try to connect to it with another PC or laptop, it will see and be able to connect to it.
