- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Orbi throttling each ethernet port speed?
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have the CBR40 modem/router combo and RBS20 sattelite. I currently pay for 330mbs connection through RCN. I've realized that i only get 330mbs plus if i connect my laptop to the first and second ethernet port. When i connect to the third or fourth ethernet port, my speeds get throttled down to about 95mbs. I have factory reset the CBR40, the same problem exists. Anyone has a solution to this?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi throttling each ethernet port speed?
IF 2 of the 4 ports are working and the 3rd and 4th ones are not, this would indicate a HW issue with the CBR40. It would need to be replaced. You'll need to contact NG support about this and ask for an RMA or return the unit to place of purchase and get another.
You can file a support ticket here:
https://www.netgear.com/mynetgear/registration/login.aspx
Reminder to post about any CBK40 issues here:
https://community.netgear.com/t5/Orbi-with-Built-in-Cable-Modem/bd-p/en-home-orbi-cable
- Mark as New
- Bookmark
- Subscribe
- Permalink
Just for our collective knowledge, what version of firmware are you on?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Currently running on V2.2.1.210
