- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Orbi wifi is half the supposed insternet speed
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
hi guys, I recently upped my xfinity internet from 175 to 600 mbps. My modem is Motorola mb8600 (replacing arris sb6141 after upgraded plan) and router is RBR50. Speed test through orbi app is showing 600+ but when it comes to ookla speed test, I only get 250-300. WiFi speed are pretty consistent around the house at that speed. Orbi firmware V2.7.0.70. Just wondering why the WiFi speed is half of the supposed internet speed and is it normal? Thanks
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Re: Orbi wifi is half the supposed insternet speed
Depending upon your device your speed testing with, most wireless devices may max out at around 400mpbs. Based on designed and support of the device.
Other factors are noise around the Orbi system, configuration and ISP modem as well.
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected. https://kb.netgear.com/000036466/How-far-should-I-place-my-Orbi-satellite-from-my-Orbi-router
What are your wired speed results with a wired PC connected to the RBR?
Do you have Armor or Cicle enabled?
Has a full power OFF of the Orbi and ISP Modem for 1 minuted then back on been performed since last FW update?
https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M970...
My Setup | ISP SparkLight | Internet Cable 1000↓/50↑ CM2000 Modem | Wifi Router RAXE50 and R8500(v.158) Router Mode | Switches NG GS105/8 |
Additional NG HW: C7800/CAX80/CM1100/CM1200/CM2000, Orbi: CBK40, CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: R7000, R7800, R7960P, R8000, R8500, RAXE500, RAX50, XR450, EX7500/EX7700, GS308v3
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
@AC16 wrote:hi guys, I recently upped my xfinity internet from 175 to 600 mbps. My modem is Motorola mb8600 (replacing arris sb6141 after upgraded plan) and router is RBR50. Speed test through orbi app is showing 600+ but when it comes to ookla speed test, I only get 250-300. WiFi speed are pretty consistent around the house at that speed. Orbi firmware V2.7.0.70. Just wondering why the WiFi speed is half of the supposed internet speed and is it normal? Thanks
Ookla is going to give different results depending on what server you connect to. Try your ISP speed test. They, even though they may use Ookla, will usually give you a more accurate reading, as the ISP will have a designated server picked.
RBK753 system/RBR750/RBS750/RBS750 + RBK853 System/RBR850/RBS850/RBS850
SXK80 — Orbi Pro AX6000 WiFi 6 Tri-Band WiFi System
There's always a logical answer, if you have all the facts!
