- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Orbi wired connection to sattelite wanlan conflict
- Mark as New
- Bookmark
- Subscribe
- Permalink
A few days back, I had to reset our router because the internet was acting weird. I have a modem/router provided by Comcast (Cisco DPC3941T). Ever since then, on one computer, I am repeatedly getting a BRS_wanlan_conflict error whenever I try to connect to a webpage that is not https. This computer is connected to the Orbi sattelite (RBS20) via ethernet. No other computers in the home are wired into either the sattelite or the router (Orbi RBR20) itself. None of them are getting the same issue, either. I have tried switching the Comcast router to bridge mode, but that did not solve the issue. What else might be happening?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi wired connection to sattelite wanlan conflict
A similar issue was resolved recently in this post: https://community.netgear.com/t5/Orbi/BRS-wanlan-conflict-html-with-orbi-and-connecting-to-webpages/...
Could this be a similar issue?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Has a factory reset and setup from scratch been performed since last update?
When you set bridge mode, did you reconfigure router mode on the RBR?
What is the default IP address of the ISP modem when in router mode? 192.168.1.1 by chance?
@ThatOneDude wrote:A few days back, I had to reset our router because the internet was acting weird. I have a modem/router provided by Comcast (Cisco DPC3941T). Ever since then, on one computer, I am repeatedly getting a BRS_wanlan_conflict error whenever I try to connect to a webpage that is not https. This computer is connected to the Orbi sattelite (RBS20) via ethernet. No other computers in the home are wired into either the sattelite or the router (Orbi RBR20) itself. None of them are getting the same issue, either. I have tried switching the Comcast router to bridge mode, but that did not solve the issue. What else might be happening?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Are you sure the modem is fully bridged? If it is, the WAN port IP address on the RBR will be a ##.##.###.### kind of address, not a 192 or 172 or a 10 IP address.
Try a full on reset and setup from scratch on the Orbi if you know for sure the modem is fully bridged.
What is the LAN side IP address for the RBR now?
