Cantonr
Jun 21, 2021Aspirant
Orbi wireless printer set up
Hi,
I have the Orbi RBR50 with 2 salalites. It is set up in router mode with a BT home hub. I am struggling to connect a Samsung wireless printer C430W. I cannot get the printer to show on the network. I have WPA2-PSK enabled. The printer is simply not found by my iPhone or a laptop. When I look at the Samsung mobile print app I see options to manually connect - RAW, IPP
- CantonrAspirantMessage cont.
SMB but these might as well be in Chinese for me. Could someone please explain in simple steps how to get this set up. I have tried using WPS on the printer and synch on Orbi but nothing happens.
Thanks
Chris- CrimpOnGuru - Experienced User
Cantonr wrote:
SMB but these might as well be in Chinese for me. Could someone please explain in simple steps how to get this set up. I have tried using WPS on the printer and synch on Orbi but nothing happens.Here's a video that explains downloading the printer software to a PC and the temporarily connecting a USB cable between PC and printer.
https://www.youtube.com/watch?v=4ZlS3stq2uE
Orbi's WPS function has worked correctly for me in the past. It is what Samsung calls PBC mode (on the left of page 108
https://www.manualslib.com/manual/1024026/Samsung-Xpress-C43-Series.html?page=108
- pabloreAspirant
After hours I finally got my wireless printer working with orbi so I thought I’d document the process here:
The printer is a dell 1160w and I set it up on a Mac.
I couldn’t for the life of me get the printer to pop up in the “devices” section.
What finally got it to work was the following:
Remove ALL security from my WiFi network.
Use WPS to connect the two.
Check ORBI webpage and ensure that printer shows up as a device.
Go directly to the IP address of printer noted in 3.
Logon directly to printer interface d - password was in the manual.
