Reply
Orbi with Circle Allow Streaming
jlandttc
Follower
I just recently got an Orbi system with Disney Circle.  I am trying to set up the time limits for children using the Circle.  Is it possible to set up a particular app (i.e. Apple Music) where the user can stream music from the app and it not go against their time lime?
Model: RBK50| Orbi AC3000 High-Performance Tri-Band WiFi System
Message 1 of 2
Guru
Re: Orbi with Circle Allow Streaming
I think you can only managed a device in the Circle app, not a application with in the device.
https://www.netgear.com/support/product/circle.aspx
https://support.meetcircle.com/hc/en-us/articles/115001381752-Filter-Platforms-Categories-and-Privac...
Might be helpful...
My Setup (Cable 1Gbps/50Mbps)>CAX80 v2.1.2.1(LAG Disabled)>RBK853 v4.6.3.16(AP) & RBK752 v4.6.5.14
Additional NG HW: C7800/CM1100/CM1200CM2000, Orbi CBK40, CBR750, RBK50(v22), SXR30(v110), R7000(v34), R7800(v84), R7960P(v82), EX7500/EX7700, XR450(v120) and WNHDE111
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 306 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
