- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Orbi with R7000 using Ethernet backhaul
- Mark as New
- Bookmark
- Subscribe
- Permalink
I’m getting ready to set up a new system using and R7000 router with the Orbi system in access point mode. I planned to use ethernet backhaul. I currently have two separate lines running to 2 parts of the house. My question is how to wire this with my 7000. Can I connect my Orbi base unit to a LAN port and the other lines to the other LAN ports of the R7000? Or do I need to run the 2 lines off of the Orbi LAN ports? In other words do I have to put the main Orbi ahead of the satellites or can they all be connected to the R7000 (acting as a switch)?
Thanks
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi with R7000 using Ethernet backhaul
Need to run two lines out from the Orbi base unit to the satellites. Or you can use a non managed switch in between the Orbi base and satellites if needed:
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have the R7800 router feeding an Orbi in AP mode at the end of a Powerline Ethernet network.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@sgmidf wrote:
......... Can I connect my Orbi base unit to a LAN port and the other lines to the other LAN ports of the R7000? Or do I need to run the 2 lines off of the Orbi LAN ports? In other words do I have to put the main Orbi ahead of the satellites or can they all be connected to the R7000 (acting as a switch)?
It should be ok to use the R7000 as a switch and connect the router and satellites through it.
- Mark as New
- Bookmark
- Subscribe
- Permalink
He want to use the R7000 as his main host router, not as a switch. The satellites need to be connect directly to the satellite base or thru a LAN switch thats connected to the R7000 router. This will work.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks
- Mark as New
- Bookmark
- Subscribe
- Permalink
You'll have to see if it works like that. Connecting the satellite to the R7000 may imped communication with the Orbi base. Then again, it may work. If the R7000 was configured for AP mode then I would say yes of course, use it as a switch. I would recommend connecting it using the recommended configuration posted by NG to minimize problems and maximize performaces. It's what I use. I have 3 switches in between my base router and satellite. Works well.
Good Luck.
