- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Orbi with fiber, outdoor extensions
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi with fiber, outdoor extensions
If the ISP router can be removed and use the Orbis router then this would be preferred. Something to ask the ISP about.
This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
- Mark as New
- Bookmark
- Subscribe
- Permalink
@Supermansings wrote:
Will the fiber go into the orbi?
No. Orbi must connect with an ethernet cable. There is no fiber input capability. The "ideal" solution is to place the Gigacenter into "bridge" or "passthrough" mode. You can see if that is possible by connecting to the Gigacenter web interface (http://192.168.1.1) using the user name and password printed on the product label. Search through the menus to see if there an option. Or, call the nice Smithville tech support line and ask them how to do it.
- Mark as New
- Bookmark
- Subscribe
- Permalink
If this is the product: https://www.searanchconnect.org/pdf/Calix_844G_UG.pdf
then I did not find an option to put the Gigacenter into bridge mode.
There IS an option to disable the WiFi on this Gigacenter.
So, the most obvious solution is to put the Orbi into access point mode and continue to use the Gigacenter to administer IP addresses, perform port forwarding (if needed), etc.
