Orbi WiFi 7 RBE973
Reply
Orbi won t connect to the internet
Efrugier
Tutor
I had the orbi for a year worked fine.
This morning it wouldn t connect to the internet. White flashing light then purple.
Checked my internet connection from modem and it it fine.
any idea what is wrong ?
Model: RBK50| Orbi AC3000 High-Performance Tri-Band WiFi System
Message 1 of 6
Guru
Re: Orbi won t connect to the internet
Do you have access to the Orbis web page?
What FW version is currently loaded?
Was a FW update done recently?
What is the Mfr and model# of the ISP modem? Built in router here by chance?
Message 2 of 6
Efrugier
Tutor
I could login to page. FW is the latest on both router and satellite. Don t know when it updated as I have auto update.
my model is a Tp link. I had it for 2 years. No issues with orbi before.
Could there be an issue with FW update ?
Message 3 of 6
Guru
What is the model# of the ISP modem?
Try a power OFF of both Orbi router and satellite for 1 minute then power back on. If this does nothing, try a factory reset on both router and satellite and set up from scratch...
Message 4 of 6
Efrugier
Tutor
Factory reset did the trick. Thanks for the advice. A bit of a pain but at least it works
Message 5 of 6
Guru
Glad that worked. Enjoy. Smiley Wink
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 6391 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi WiFi 7
