- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Orbi wont connect to my internet nor my ps4
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi wont connect to my internet nor my ps4
It often helps to "start at the beginning." i.e. We assume this is a new Orbi RBR20 that you have just installed (not one that has been working fine for some time)?
What is the Orbi WAN (yellow) port connected to? i.e. the brand and model of cable modem/router and which internet service provider you have (Comcast, Spectrum, AT&T, Google, etc.)?
How are you connecting the Play Station 4 (ethernet cable? WiFi?)
If you plug the PS4 directly into the internet modem, does it work then?
- Mark as New
- Bookmark
- Subscribe
- Permalink
What FW is currently loaded?
Is the Orbi system operating in Router or AP mode?
Has a power off of the ISP modem and Orbi router for 30 seconds then back on with the modem first, then the Orbi router been performed?
@TrevorLRad wrote:
My RBR20 says the internet is online and has 1 satellite connected. The only issue is as i check on the your products tab it says im not connected to my internet. I try to connect my orbi wifi to my ps4 and it comes up with a CE-37813-2 error code.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Any progress on this? Just checking.
