Discussion stats
  • 4 replies
  • 135 views
  • 0 kudos
  • 3 in conversation
Announcements
Top Contributors
Reply
Highlighted
Orbi worked for 3 months, then dropped Internet completely
 I bought an Orbi RBK50 with two satellites back in October 2019. It worked well until a couple of weeks ago when it dropped its connection with the Internet. I didn't change anything. I have tried setting it up again multiple times with no result. The satellites are powered on but they don't sync with the main unit no matter what I do.
I looked up similar complaints. It said SOLVED and had a link to a solution, but there was no solution at the link and the topic was closed.
Can anyone please help me. Is it just broken?
There doesn't seem to be any Netgear support. Please tell me if there is. I paid quite a bit for the system and this is very disappointing.
Geraldine
Message 1 of 5
Highlighted
Guru
Re: Orbi worked for 3 months, then dropped Internet completely
Please post about this over in the Orbi AC forum for your model Orbi:
https://community.netgear.com/t5/Orbi/bd-p/Orbi
Thank you.
My Setup (Cable 900Mbps/50Mbps)>CAX80>Orbi RBK50 v2.5.1.16(Router Mode)
Additional NG HW: C7800/CM1100/CM1200, Orbi CBK40, Orbi RBK50/RBK853, R7800, R7960P, EX7500/EX7700, XR450 and WNHDE111
Message 2 of 5
Highlighted
Guru
Power OFF the ISP modem and RBR for 30 seconds then back ON.
Geraldine
Message 3 of 5
Highlighted
Retired_Member
Not applicable
post in another forum...and now more questions...???
wow and wow
Message 4 of 5
Highlighted
Guru
Any progress on this?
Geraldine
Message 5 of 5
