Reply
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Orbi
- Mark as New
- Bookmark
- Subscribe
- Permalink
2017-08-17
02:40 PM
2017-08-17
02:40 PM
Orbi
The white Orbi cases are smooth plastic but soft unlike any other electronic plastic. How can they be cleaned? Specifically removing ball point ink scribbles by a toddler. Asking for a friend . . .
Model: Orbi High-Performance AC3000 Tri-Band WiFi System (RBK50)
Message 1 of 2
Labels:
- Mark as New
- Bookmark
- Subscribe
- Permalink
2017-08-17
03:29 PM
2017-08-17
03:29 PM
Re: Orbi
hi , it really depends if its ink type ball point pen or gel type but try
get amonia and a cotton bud and apply the amonia just to the actual ink and let it sit for a while and then use another cotton bud to dab it off
note : i have not tried this but suggest you do a small test sample on the back of the unit forst to make sure it doesnt effect the plastic
Message 2 of 2
Announcements
