Orbi WiFi 7 RBE973
Reply
Orbi
Thursdayschild
Follower
Orbi
My family and I are looking to invest in the Orbi mesh system. Can anyone advise the difference between the RBK 50 and 53 Versions? Many thanks
Model: RBK50| Orbi AC3000 High-Performance Tri-Band WiFi System
Message 1 of 2
Guru
Re: Orbi
The kits are the same hardwardwise, The kits I believe are different in that the RBK50 has just the one base router and 1 satellite while the 53 has 2 satellites. You can look at the spec here for each system:
https://www.netgear.com/support/product/orbi.aspx
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 510 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
