Reply
Orbi
Ben_Alb
Orbi
My orbi router keeps disconnecting certain devices from the internet at times around 10 pm despite no internet block in place...
Message 1 of 6
Guru
Re: Orbi
What FW is currently loaded?
What model Orbi do you have?
Is the Orbi system operating in Router or AP mode?
What devices do you have connected to the system? wireless and wired?
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials.
What WPA security modes are you using?
Try enabling Beamforming and MIMO.
Daisy Chain, Fast Roaming, IPv6.
My Setup (Cable 1Gbps/50Mbps)>CM1200 v2.02.03(LAG Disabled)>RBK50 v2.7.2.104(WW)/RBK853 AP Mode v3.2.18.1
Additional NG HW: C7800/CM1100/CAX80/CM2000, Orbi CBK40, R7800, R7960P, EX7500/EX7700, XR450 and WNHDE111
Message 2 of 6
CrimpOn
Sensei
Re: Orbi
Would you mind sharing more details about this situation?  Such as:
Specifically which devices get disconnected?
Is it every night about 10pm, or just some nights?
I love my Orbi.
Message 3 of 6
Ben_Alb
Re: Orbi
It is every night and the devices are my phone and Xbox.
Message 4 of 6
CrimpOn
Sensei
Re: Orbi
And there are other devices which never get disconnected at 10pm?
How do you get the phone and Xbox to connect again?  (turn them off and back on?  wait until they reconnect automatically?)
We usually ask which specific Orbi model you have and which firmware it is running, and also which specific model of modem the Orbi is connected to.
I love my Orbi.
Message 5 of 6
Chuck_M
Mentor
Re: Orbi
This could be another lease time problem.
My Equipment: Cox Cable (350Mb/35Mb), Orbi AX6000 (RBR850, 3 x RBS850) (2xWired backhaul), NG GS116PP Gigabit Smart Switch, Synology DS1019+ NAS
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 730 views
  • 0 kudos
  • 4 in conversation
Announcements
