Orbi WiFi 7 RBE973
Reply
Orbi
davidloepp
Orbi
Well I’ve decided to go against all my years of using a router and bought an Orbi. As much as I wanted to get the Nighthawk AX8 or wait for Orbi’s Wi-Fi 6 to come out, I needed to get something now. Just too many devices where I feel my router is taking a beating and the fact it’s 3 -1/2 years old is a contributing factor as well. I get 30 days to try it. All satellites will be hardwire so I hope there won’t be a disappointment in speeds and range. Wish me luck.
Model: RBK43| Orbi AC2200 WiFi System
Message 1 of 6
Accepted Solutions
Guru
Re: Orbi
Oh yes, of course, if there going to be wired, then distance can be much greater as they wont be depending upon wireless backhaul and DS would need to be disabled anyways in that configuration.
Message 6 of 6
All Replies
Guru
Re: Orbi
I've enjoying mine. So has my friend down the road:
https://community.netgear.com/t5/Orbi/Orbi-firmware-update-v2-1-4-16-availability/m-p/1592753/highli...
Good Luck Smiley Wink
Message 2 of 6
davidloepp
Re: Orbi
Forgot to ask??? Did NETGEAR update the firmware for this unit on the satellites being able to talk to one another or is it still where they only can communicate with the router only. Also what’s the max amount of satellites that can be added. Thanks
Message 3 of 6
Guru
Re: Orbi
You mean Daisy Chain? It's been there. Though maybe some issues. DS should be working as of v32 at least. Saw odd issues with v210.
Seen some have up to 6 on the RBS50. Not sure if the 40 series would do the same. I think officially they support 3.
Reminder that adjust the Orbi and add additional satellites for the size of the home and placement seem to start at 30 feet in between the base and satellites.
Message 4 of 6
davidloepp
Re: Orbi
Yes Daisy Chain. Now when you say 30 feet between Router and Satellite your only talking initial setup right. Since their all going to be hardwire to each other I hope the distance apart can be greater than 30 feet.
Message 5 of 6
Guru
Re: Orbi
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 1718 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
