Orbi WiFi 7 RBE973
Reply
Orbi
Kaysee326
Follower
Orbi
Hello
Are you able to buy additional Orbi satellites to connect to the existing Orbi network.
ie - if i buy a set of 3 (Router and 2 satellites), can I just buy an additional satellite for more coverage?
Message 1 of 2
Accepted Solutions
Guru
Re: Orbi
Yes you can. RBS or RBW models will work. RBRs only work as main router or in AP mode. They can not work as a satellite.
Message 2 of 2
All Replies
Guru
Re: Orbi
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 919 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
