- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Orbi
- Mark as New
- Bookmark
- Subscribe
- Permalink
Orbi
Good afternoon,
I might be asking a question that has been answered multiple times before...
When installing an Orbi system, 1 router, 3 access points, do the 3 AP's have to be in reach of the router or does one AP forward the signal to another one? The reason I'm asking the question is because in the manual of the Orbi system, the drawings seem to suggest that all AP's have to be in reach of the router. My desired setup would be to have the router at ground level and then one AP per level. Will this work?
Thank you for your time and support.
Br,
Jérôme
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi
@JSchepers wrote:Good afternoon,
Br,
Jérôme
Hi, the satellites can forward the signal from the router when the option Enable Daisy-Chain Topology is enabled under Advanced > Advanced Setup > Wireless Settings.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi
Thx for your swift reply. It makes sense but I can't seem to find any reference of this option in the manual. Is it a recent addition?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi
Daisy Chain has been around for a while now.
https://kb.netgear.com/000048458/What-is-daisy-chain-and-how-does-it-work-with-my-Orbi-WiFi-System
https://kb.netgear.com/000048459/How-can-I-see-if-my-Orbi-WiFi-System-is-using-daisy-chain
https://kb.netgear.com/000048460/How-do-I-disable-daisy-chain-topology-on-my-Orbi-WiFi-System
@JSchepers wrote:Thx for your swift reply. It makes sense but I can't seem to find any reference of this option in the manual. Is it a recent addition?
