Orbi WiFi 7 RBE973
Reply
Orbi
BigOrod
Follower
Orbi
So, do I disconnect from my old router on my modem. I think mine is a combination of both on my modem/router. So i got the Orbi for better connection throughout the house. So do I just login all devices to Orbi? Can I still use the other one as well?
Model: RBR20|Orbi AC2200 Tri-band WiFi Router
Message 1 of 2
Guru
Re: Orbi
Well not much info on here.
what modem/router combo device are you using? if it is a combo device, I recommend putting it in gateway more or passthrough mode. Otherwise you'll have a double nat setup that will cause issues.
https://kb.netgear.com/30186/What-is-Double-NAT
Should you not choose to do so, I wouldn't recommend running your combo device's wifi and the orbi wifi as well. this will just add interference to the Orbi setup. Orbi is fairly robust and can run quite a few devices.
You also have the option of putting the orbi in AP mode if you don't want to put your combo device in passthrough/gateway device mode.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 490 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
