- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Orbi
- Mark as New
- Bookmark
- Subscribe
- Permalink
Orbi
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi
There is more than one way to interpret this question. (a) the camera is working fine connected to 5G channel, but you would prefer that it connects to the 2.4G channel, or (b) you cannot configure the camera and believe that the Orbi 5G is interfering with the process.
(a) or (b)?
What brand and model of camera is it?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi
I ask because there appear to be only two Wyze WiFi cameras and neither of them can connect to a 5G network. (The detailed specs are very clear on the product web page:, https://www.wyze.com/wyze-cam/
"WiFi 802.11 b/g/n 2.4GHz (Does not support 5GHz network) Supports WPA and WPA2 protocols".
What this means is (literally) the Wyze camera cannot possibly detect a 5G WiFi signal. It cannot possibly connect at 5G.
I personally own the $19.99 Wyze Cam, and it connected immediately to my Orbi RBR50 at 2.4G the way it is supposed to and is working now. I used the Android smartphone app to set it up, look at the live feed, and view recordings.
So, the support person at Wyze was "misinformed" (to put the kindest slant on it). To be more brutal, he was full of s**t.
Now, having vented, there is obviously a problem with getting the Wyze camera to work. What specifically is the error? Or, at what point in the setup does it fail?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi
I actually purchased my Wyze Cam because back in May there was a discussion about installing a Wyze Cam:
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi
Oh, dear. Since the Wyze Cam has no 5G radio, it cannot connect to a 5G WiFi. It appears you have a desktop PC. Please connect to the Orbi web interface (either "orbilogin.com" or 192.168.1.1), enter the user ID "admin" and the administrative password (not the WiFi password), and bring up the Attached Devices page.
I have seen reports that the smartphone Orbi app is sometimes incorrect about the type of connection.
It also appears that the smartphone is trying to connect over the mobile network (LTE). Was the Wyze camera set up using WiFi, and did it work at that time?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi
@CrimpOn wrote:....... Since the Wyze Cam has no 5G radio, it cannot connect to a 5G WiFi. .......
@Mbluman Do you have a repeater of any type that the camera is attaching to on the 2.4 GHz?
Can it be that repeater (or some other device in between the camera and Orbi) is attaching to Orbi on 5 GHz and the camera is attaching to that device on 2.4 GHz?
You can easily confirm this by checking the MAC address shown in the Orbi app and compare it with the MAC address of the camera.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi
You can disable the 5Ghz SSID temporarily to see if the camera will connect to the 2.4Ghz radio SSID. Under Advanced Tab/Advanced Settings/Wireless Settings. If you try this, see if the camera connects, if it fails to work even on 2.4Ghz, then there maybe problem with the camera sicne your other cameras are working.
