- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Orbi
- Mark as New
- Bookmark
- Subscribe
- Permalink
Orbi
Is there a way to turn off the 2.4 GHz band or be able to select a channel.
Thank you,
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi
Using the Orbi web interface, it is possible to:
- Reduce the transmit power of each WiFi band (2.4G and 5G separately)
- Stop broadcasting the SSID (each band separately)
- Select the channel (each band separately)
This is on the Advanced Tab->Advanced Setup->Wireless Setup
"Turn off completely". No.
One wonders what the desired result is. Is there some problem this is supposed to solve?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi
You can disable the SSID broadcast if this is what your need.
You can manually select channels for either radio. Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz. Basic Tab/Wireless settings.
@Hula wrote:Is there a way to turn off the 2.4 GHz band or be able to select a channel.
Thank you,
