Reply
Highlighted
Follower
Orbi
I’m trying to install the Orbi. It first said can’t find network. I rebooted the modem. It now says wrong password. Please help.
Message 1 of 4
Highlighted
Sensei
Re: Orbi
Are you setting up the Orbi using the web interface (web browser) or the Orbi "app"?
The WiFi SSID and password are printed on the product label on the bottom of the router.
If you enter the product number on this web page, you can get the entire User Manual and installation guide:
https://www.netgear.com/support/
I love my Orbi.
Message 2 of 4
Highlighted
Master
Re: Orbi
Is this the initial setup? If it is, rather than waste a lot of time trying to figure it out, reset the Orbi router and start again.
Orbi RBK53 System/RBR50/RBS50/RBS50. + Orbi Voice RBS40V
RBK753 system/RBR750/RBS750/RBS750 + RBK853 System/RBR850/RBS850/RBS850
There's always a logical answer, if you have all the facts!
Message 3 of 4
Highlighted
Re: Orbi
Did you also reboot the Orbi after you restarted the modem?
Just another user.
My network DM200 -> R7800 -> GS316 -> PL1000 -> Orbi RBR40 -> Orbi RBS50Y -> RBS40V
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 111 views
  • 0 kudos
  • 4 in conversation
Announcements
