Orbi WiFi 7 RBE973
Reply
Orbi
bythebay
Orbi
Hello,
I need some help with the resetting the admin/password for Orbi RBK50.
I purchased the RBK50 from Amazon as an openbox from Amazon Warehouse 03/29/21 and received it today 04/01/2021.
The setup process was a breeze on the app until the "Login Requried" section where the username is: Admin
Since this was a previously returned item, I'm pretty sure the person that returned it had previously setup a password
and also completed the password recovery questions section and so far I haven't found any answers on how to reset this.
I can provide serial # and proof of purchase if needed.
Thanks!
Model: RBK53|Orbi AC3000 Tri-band WiFi System
Message 1 of 7
Accepted Solutions
bythebay
Re: Orbi
Dang, didn't think it was that easy! I will do that and Thanks!
Message 3 of 7
All Replies
CrimpOn
Guru
Re: Orbi
@bythebay wrote:
Hello,
Just do a Factory Reset on the router and the credentials will be reset to "admin" and "password."
The WiFi will be set to what it printed on the product label.
https://www.youtube.com/watch?v=cMw4ePACgc4
Good Luck
Message 2 of 7
bythebay
Re: Orbi
Message 3 of 7
alexusman
Re: Orbi
I agree that Orbi system needs to support hard wired ethernet backhaul.  I have had so much trouble with my satellite that I have actually just turned it off.  I see posts in which Netgear employees acknowledged the need for this feature.  How long should it take?
Message 4 of 7
CrimpOn
Guru
Re: Orbi
This entry appears to have been added to the wrong post.  The Orbi system already supports ethernet backhaul between satellites and router and also between satellites.https://kb.netgear.com/000051205/What-is-Ethernet-backhaul-and-how-do-I-set-it-up-on-my-Orbi-WiFi-Sy...
Message 5 of 7
johnalex
Re: Orbi
Not saying it doesnt support it. I am saying that the RBR50 and RBS50 are flaky and hard to manage when setup in backhaul mode. I have both the base and satellite connected to the same switch (unmanged switch made by Netgear) and the base station still shows a magenta light thinking its offline, Internet works, and i can only use the orbi app if my iphone is connected to the base stations wifi, not the satellite
Message 6 of 7
CrimpOn
Guru
Re: Orbi
Could you make a rough drawing of how the modem, Orbi router, switch, and Orbi satellite are all connected?
Is it:
modem---Orbi router---switch---Orbi satellite and other devices?
Message 7 of 7
Top Contributors
Discussion stats
  • 6 replies
  • 1156 views
  • 1 kudo
  • 4 in conversation
Announcements
Orbi WiFi 7
