Orbi WiFi 7 RBE973
Reply
Orbi
Tony-W
Follower
Orbi
Hi. have the Orbi systems and I just about to change internet providers. They have the the following routers:
Netcomm NF18MESH
D-Link Viper 2600
Which one is best for my existing system. Is there any system changes that I will need to make.
Thanks
Model: RBK53|Orbi AC3000 Tri-band WiFi System
Message 1 of 2
Guru
Re: Orbi
If you have a Orbi mesh system already, then ask the ISP for a modem/ONT option only. You don't need another wifi router in front of the Orbi router. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
If you do have to get a modem/router combo, Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
https://kb.netgear.com/000061277/Which-features-are-disabled-on-my-Orbi-router-when-it-is-set-to-AP-...
We don't have any information on those items you mentioned.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 400 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
