- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
OrbiOS 2.1.1
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Re: OrbiOS 2.1.1
yep, almost 24 hours on the orbi pro for me, with no drops, no hiccups at all..
new firmware ending in .34 to fix the Krack Exploit and still working strong
weird thing; since .34 firmware, I now get 2 "versions" of my wifi network on many devices, one being a 2.4 flavor of my wifi, and the other being a 5ghz flavor of it, and I can choose right on my device which band I want to connect to...never had this before on any of the mesh type systems I have tested over the last 30 days..
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Re: OrbiOS 2.1.1
The latest Orbi Pro beta is still on the 1.x branch (1.12.1.38), so it's not expected to have the drop problems that the 2.x branch has.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Re: OrbiOS 2.1.1
Wase4711
I'm at V2.0.0.74 with an RBK50 router and two RBS50 Satellites that have been installed for a few months. When I installed my Ring Doorbell 2 I began experiecing dropped Internet connections, unable to access the Orbi Router, etc. I've read multiple people noting that same problem in the forum and I just wondered if you have a Ring Doorbell installed and are not experiencing these issues?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Re: OrbiOS 2.1.1
yes, I have a Ring Doorbell pro installed, and no drops with the orbi Pro..
Also have 2 Arlo Cameras installed, and no issues with those either with the Orbi Pro
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Re: OrbiOS 2.1.1
I tried downgrading mine to 1.11.0.20 after it auto-updated itself and it can't. I update and as soon as the router comes back it shows V2.0.0.74.
I tried 1.4.0.16 and got somewhere... after the reboot it showed the version as 1.4.0.16. Then I tried 1.11.0.20... but same thing, it jumps immediatly to 2.0.0.74.
Next I tried putting 1.4.0.16 then quickly telnet-ing in to change the auto-update settings. I managed to do so but then it rebooted and updated to .74! It likley already checked the auto-update setting before I got to update it. So... now I'm stuck.
This is ridicuous. To make matters worse I emailed support and they didn't even read what I said.... Their response was to update to 2.1.1.16!! This is seriously infuriating!! Netgear neads to issue a recall on this garbage.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Re: OrbiOS 2.1.1
@tinypocket wrote:I tried downgrading mine to 1.11.0.20 after it auto-updated itself and it can't. I update and as soon as the router comes back it shows V2.0.0.74.
Could you downgrade, disconnect your internet modem, do the telnet work to disable auto update, then reconnect internet modem?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Re: OrbiOS 2.1.1
If you turn off auto-update using the nvram commands they will stick, so let it upgrade to whatever version it wants, then turn off auto-upgrade, then downgrade. You'll see a notice on the web GUI that there's a new version available, but it won't upgrade itself.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Re: OrbiOS 2.1.1
1) stay on .74
2) telnet and disable auto updates
This should stick
3) downgrade satellite
4) downgrade router
5) optional - after downgrading to 1.x.20 should I factory reset the router and satellite and set up as new?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Re: OrbiOS 2.1.1
I pulled the internet connection before I downgraded mine. After it booted to the downgraded version, I went in and disabled auto-updates. After that I re-attached it to the internet. Mine didn't automatically upgrade.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Re: OrbiOS 2.1.1
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Re: OrbiOS 2.1.1
After uploading the beta firmware 2.1.210, the connection drops seems to have stopped. I uploaded to the satellite first as instructed, then to the main one and everythings is working fine for now. I will continue to monitor as see if it stays stable.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Re: OrbiOS 2.1.1
Blocked auto updates with Telnet. The only strange issue I'm having with 1.x.20 that I was having with .74 is sometimes my devices connect and it says "Connected. no internet"
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Re: OrbiOS 2.1.1
**Edit: Nevermind, working now.
Have been trying to get the link to work (multiple machines, mutliple browsers... no joy), then I post this, and suddenly it works. :S
WAS:
Is anyone else having issues downloading the 2.1.2.10 beta firmware for the rbs50 (sats)?
The link isn't working... (?).
Could someone please advise if there's an updated version or link (?).
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Re: OrbiOS 2.1.1
Here is the article that I found that seems to tie it together: https://www.myce.com/news/confirmed-issue-google-cast-causes-temporarily-wifi-drops-around-world-834....
It looks like there might be other issues with Google cast devices and MDNS packets as well like: http://www.androidpolice.com/2018/01/12/google-home-max-appears-killing-wifi-networks/.
I do have a Chromecast on my network, but I so I might unbox my Orbi again and see if that is the culprit...
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Re: OrbiOS 2.1.1
Anyone aware if a new Beta is going to be released so we can test it if better than the current ?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Re: OrbiOS 2.1.1
I had one of these Google devices on my network in November with no noticeable reboots. However, I added 3 more devices on my network at about the time the reboots became a problem. TP-Link resolved the issue with a router firmware update. Netgear, will you please look into this?
I'm going to see if there's a workaround other than removing the devices from the network.
Thanks newbeb!
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Re: OrbiOS 2.1.1
Which system has similar power to Orbi? I'm almost ready to jump ship. I did a full power cycle this morning incl. Modem and switch, router and satellite full reset. Hopefully that cures the "Connected, no internet" problem which occurs if I turn off wifi then turn it back on for a PC and 2 Android devices.
I need something to cover a 2 story home. 2800 sq ft. A couple dead zones around corners which orbi did great. 2 TV's with Netflix, Amazon etc plus occasional Skype or WebEx.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Re: OrbiOS 2.1.1
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Re: OrbiOS 2.1.1
generally speaking, do you get faster speeds if you are connected as a router or an access point, or is there no difference?
often, the system works fine either way, but, not sure if one way gives faster wifi speeds than another..
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Re: OrbiOS 2.1.1
It should not be enough of a difference to notice in any application. What you get with using one router is the simplicity of setup and knowing what is causing the issue if you have one. Also I wouldn't trust my ISP to provide the router because of their access to it otherwise I would have to buy my own router and then I have two pieces of equipment to upkeep.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Re: OrbiOS 2.1.1
I know some wireless routers wont work when you connect them to another router, unless they are connected as an access point; the orbi pro, works either way,just wondering if it would be faster as a AP versus a router, since I have it connected to my Cox router now..
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Re: OrbiOS 2.1.1
You never want to have a router behind another router that is handling internet routing. That's known as double-natting and causes problems with a lot of applicaitons.
The Router that is behind an active router on the internet should always be an AP only, unless you know why you want to double NAT and are trying to achieve something very specific such as isolating an application or set of users.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Re: OrbiOS 2.1.1
thats what I thought too, but even Netgear says that with the Orbi pro, this is perfectly acceptable..
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Re: OrbiOS 2.1.1
Using AP mode and the latest beta, I get same internet connection speeds using WIFI from all satellites and the router. This is the same speed I get hard wired from the Fios router which has the WiFi turned off ~85 up and down I measure using speakeasy and speed test. I use both IPhone and IPad I get the same results with my hard wired PC. Jitter is low and I am getting 0% loss in my tests.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Re: OrbiOS 2.1.1
I have 1 gig cox service, and my faster wifi speeds are never more than 500 megs up or down with the orbi or orbi pro; any way to improve this, or is this the best you can expect?
using AP mode or router mode, plugged into the cox netgear ac1750 router they provide
