- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
OrbiOS 2.1.1
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: OrbiOS 2.1.1
This latest beta update (2.1.2.10) has resolved all of the issues I was having with disconnects and with not showing devices connected to my 2 satellites.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: OrbiOS 2.1.1
Im re-reading the original message and I just want to confirm this beta does NOT address the bug where orbi wont save special characters in password, correct?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: OrbiOS 2.1.1
@lowepg wrote:Im re-reading the original message and I just want to confirm this beta does NOT address the bug where orbi wont save special characters in password, correct?
That appears to be the case from the message, but if you are on 2.1.1.12 or 2.1.1.16, you don't have anything to lose by trying this one. I tried adding a $ in my guest password and that worked, but I have seen another user has trouble with extremely long passwords still.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: OrbiOS 2.1.1
I have just upgraded to 2.1.2.* on RBR40 and RBW30 satellites. Internet connection is stable. CPU observed so far lines up with what others have posted. Will apprise.
My only (tiny) complaint is there is no graphic setting for an assitant device like Echo or Home.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: OrbiOS 2.1.1
I had one restart at 2 hours. Debug shows system uptime of two hours but it definitely bumped some devices off because their addresses changed.
I'm thinking of a reset. in real world shouldn't have to do this but since Netgear released a buggy update and we here are savvy enough I'll try it. Then it's back to .74. Even .74 improved with a reset.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: OrbiOS 2.1.1
Update: one of my satellites keeps showing a blue ring. Diagnosing.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: OrbiOS 2.1.1
@dpaugro wrote:Update: one of my satellites keeps showing a blue ring. Diagnosing.
I unplugged and replugged it. Blue light went away after a minute or two, which is longer than the stated 10 seconds on the KB site. I'm watching uptime on that satellite. The other satellite has not exhibited problems and uptime indicates no restarts since I upgraded firmware.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: OrbiOS 2.1.1
Router rebooted after 3 hours. Back to .74. So frustrating
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: OrbiOS 2.1.1
Updated rotuer and satellite with great results!
Everything running smooth and attached devices now display correctly.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: OrbiOS 2.1.1
Thanks for this beta firmware.
I gave it a shot because I add some random reboots (not much) and because the attached device list was wrong.
Updated to 2.1.2 one hour ago 2xRBS50 + 1xRBS40 + RBR50. Everything running smooth. So far so good. Attached device list is correct. I'll update my feedback after few days.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: OrbiOS 2.1.1
One of the less painful upgrades, everything went smooth. Devices connected right up the Sat and Router and information on connections are correct Will monitor
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: OrbiOS 2.1.1
The upgrading to beta firmware was smooth. Result was great so far. Will try wired backhaul and report after a longer test.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: OrbiOS 2.1.1
The issue seemingly related to Android phones is still present. I installed the beta late last night and this morning the router rebooted when my Android phone alarm went off.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: OrbiOS 2.1.1
Good until I used my Android phone and the system rebooted. Android reboot issue is not fixed.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: OrbiOS 2.1.1
Installed the beta and went to a wired backhaul. When I had the sat direct connected to the router...it kept going in and out of a status of Poor on the status page and the satelite kept flashing pink. The strange thing is when I put my switch between the two...it has been stable and doesn't keep slipping into poor quality and flashing pink on the sat. I think there's some work to be done on the wired backhaul still I should be able to hook them up direct. When it was conected direct and i was able to run a speed test I got 5-10 was all..with the swith in place i get 250...this is on a wired connection to the satelite.
Adding in an update..wireless speed tests connected to the sat which is wired to the router with the switch in between gave me about a 230 speed which is what i would expect. so i am happy with that i would just like to direct wire the sat and the router and skip the switch in the midddle.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: OrbiOS 2.1.1
this has been worse than 2.1.1.16 in my case. Since updating last night, I've had 2 or 3 router reboots, 1 satellite reboot, and 1 maybe two dropping all wifi connections.
I did not reset the router after updating. I just updated and ran it. Need to work at home today so going back to 2.0.0.74
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: OrbiOS 2.1.1
@Blcklab wrote:this has been worse than 2.1.1.16 in my case. Since updating last night, I've had 2 or 3 router reboots, 1 satellite reboot, and 1 maybe two dropping all wifi connections.
I had a mod PM me about having any Android 8.0 devices in my household because that fix is NOT in this beta, closest thing I have to an Android device is a Chromecast which wasn't turned on during my testing.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: OrbiOS 2.1.1
I do. However I haven't noticed getting "kicked off" when that device connects or wakes. Sometimes it runs fine. Sometimes not. Either way I need to use my phone at wifi where I live.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: OrbiOS 2.1.1
Had all the reported problems with 2.1.1.16 with a barely functinoal system. Kids all switched to Verizon LTE. It was awful. Had to manually reboot system several times a day just to be able to watch streaming TV and browse on Apple devices. Hardwired devices were ok.
Updated to 2.1.2 beta and it is much better. Still getting occasional connection problems where device stays connected, but unable to get through to Internet. Have not had to reboot router system since going to 2.1.2 though. The connection problems recover after about a minute or two. Devices are now connecting to satellites while the 2.1.1.16 almost everything connected to base router unless it was literally next to a satellite.
Summary - 2.1.2 is definitively better than 2.1.1.16 but still not a true fix
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: OrbiOS 2.1.1
Does the beta have the KRACK patch?
Despite intially having a decent experience with 2.1.1.16, I eventually downgraded to 2.0.0.74 after some stability issues with 2.1.1.16
I am happy to stay with 2.0.0.74 for the now so long as the beta does not give me anything urgent / beneficial above 2.0.0.74. I know the connected 'devices list' is fixed in the beta, but anything else compelling that the beta includes above 2.0.0.74?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: OrbiOS 2.1.1
I would say just Disney Circle if you wanted to use that...and wired backhaul if you can get it to work
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: OrbiOS 2.1.1
Just updated to the beta.
Some dievices are showing on th Sats. I will check later in day for full connections.
CPU loads are
RBR50 13.5%
Near Sat 30.*% 5g connect
Far Sat 21.4 % 5g connect
AP mode
updated manually with no reboot.
So far so good.
Previously I had 15 days on 16 with no issues otehr than lasck of Sat UI info.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: OrbiOS 2.1.1
@morrisseysb wrote:I would say just Disney Circle if you wanted to use that...and wired backhaul if you can get it to work
Thanks!
Disney Circle is not required in my case and my home layout (open floor plan and no ethernet wiring) is not conducive to wired backhaul without it looking messy...
So, just to (re)confirm, this beta firmware does not include the patch for the KRACK vulnerability?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: OrbiOS 2.1.1
@PyroDog wrote:Updated rotuer and satellite with great results!
I take back what I said. Still having issues:
https://community.netgear.com/t5/Orbi/Packet-loss-pattern/m-p/1479220#M20248
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: OrbiOS 2.1.1
All firmware .76 and above should have the patch for KRACK. So yes, it must have the patch.
However, I would be careful as I think this firmware still has some bugs introduce with 2.1.1.12 - possibily the long password trunkation and illegal special characters in passwords that where working before. You can try it out but be ready to roll back to .74 if you have issues until the official release of 2.1.2.x
