Orbi WiFi 7 RBE973
OrbiOS 2.1.4 + Homekit
EagleKlaw
Tutor
Re: OrbiOS 2.1.4 + Homekit
Is is correct that the version linked to the RBX40 links are V2.1.3.6 where as the versions for the RBX50 and RBX20 are V2.1.4.14?
Message 26 of 114
turns2stone
Apprentice
The firmware posted for the RBS50Y has the same version number: 2.1.3.4, although the file is indicated as "V2".
I updated to V2, but behavior is the same (nothing can connect to the Orbit Outdoor). I guess I'm off to do some rebooting/troubleshooting....
Message 27 of 114
kmaple
Tutor
I gave this another try and relaunch all my unresponsive homekit accessories and it seem to be working great.
Thank You
Model: RBK50| Orbi AC3000 High-Performance Tri-Band WiFi System
Message 28 of 114
DarrenM
Sr. NETGEAR Moderator
The Links for the RBR40 RBS40 and RBY50s have been all updated to the correct files.
DarrenM
Message 29 of 114
DarrenM
DarrenM
Message 30 of 114
oncodude
I went to perform the manual install, but my system was already running on 2.1.4. And my HomeKit is not working. Do I need to perform the manual install anyway?
Message 31 of 114
turns2stone
Apprentice
Thanks. Now that the correct RBS50Y firmware was posted, all satellites are behaving nicely with HomeKit.
Message 32 of 114
DarrenM
Hello oncodude
Yes manual install over that firmware.
DarrenM
Message 33 of 114
AC641
Luminary
Does this fix include Philips Hue?  It's not strictly Apple HomeKit but works using the same back-end.
Message 34 of 114
eljarviso
Luminary
It should. I believe it’s a tweak to how it handles mDNS.
Message 35 of 114
rlmancebo
I have updated my RBR50 without problem. When I try to update the RBS50's it fails with a message stating the file is not correct. How do I get the Satellites updated?
Model: RBS50| Orbi AC3000 Tri-band WiFi (Satellite Only)
Message 36 of 114
EagleKlaw
Tutor
After much teeth nashing, pulling of hair, swearing, etc. I finally got my system back up and running on 2.1.4.14 on a wired backhaul.  I finally had to factory restore everything, reloaded firmwares, say a prayer, and finally it is up and running.
My Homekit stuff seams to be ok for now, but I am still getting "unreachable" message on most of my Hue stuff.  Hopefully you have had better luck.
After many wasted hours spent fighting this system this week, I can't take any more, so hopefully it will stay stable and they won't push another auto update that breaks it all again.  I don't think my mental health can take it.
Message 37 of 114
oncodude
I have the same problem, but I started with the sattelite, as instructed
Message 38 of 114
cheshbr
Apprentice
Done this and it works for me
Message 39 of 114
AC641
Luminary
Updated to v2.1.4.14 on both RBR50 and RBS50 (satellite first).  The update went smoothly.  It will take me a few days to determine whether it has cured my issues with Philips Hue Routines becoming unreliable; here's hoping!
Message 40 of 114
cheshbr
Apprentice
Where are you getting FW V2.1.4.14 from?  Only recently Netgear releseased FW V2.1.4.10-0430-dbg for which I was a beta tester.  Previously I was having major issues when upgrading to FW 2.1.3.4 and FW 2.1.4.10, which buggered up my Homekit and Lifx devices, so I downgraded to FW V2.1.2.18, but once I installed V2.1.4.10-0430-dbg about a week ago after working with Netgear, my system has been perfect for at least a week.
Message 41 of 114
cheshbr
Apprentice
Message 42 of 114
AC641
Luminary
From the links posted in the very first post in this thread.
Message 43 of 114
khudsn7
Star
I have been having this SERIOUS problem with many of my homekit products displaying "no response".  I updated to the newest version 2.1.4.14 which was suppose to fix this.  It DID NOT fix it for me.  Still...most of my homekit devices are still showing "no response".  Why is this still happening?  Is there some special thing I need to do...to get this new version to work with homekit?  The devices work fine in their respective apps but in homekit, they show "no response".  PLEASE HELP!
Message 44 of 114
siuolly
Star
Using my Mac osx 10.13.4 downloaded the link for the RBR50 which is a dmg file.  The downloaded file says 31.MB and your server says 29 MB.  After download, my Mac can't open it, it says invalid image.  Did it like 10 times and same result.
Message 45 of 114
usahale
Star
Delete the old downloads and try again. I have same OS as you and no issue. File is .img when I just checked. Yes, Finder will say 31.1MB, difference in disk access standards.
Sorry, just realized what you're doing. You shouldn't opening the file in your Mac, you should usually Manual Update option in Orbi itself. I posted the steps earlier in this thread.
Just download the img file(s) to your Mac, login to your Orbi, Advanced, Administration, Firmware Update, Manual. Do the sat first, when it’s rebooting do the router.
Message 46 of 114
Sdiver2489
Apprentice
I've brought this up in previous threads but my only issue I am having is that my rainmachine (and maybe other devices?) seem to lose connection randomly and then don't pick the connection back up from the orbi when this happens. I never had this issue with my Asus N66U router so I'm pretty sure this is an Orbi specific bug much like this Homekit issue. Who knows maybe the homekit fix would fix this issue? When this issue happens my log is full of DHCP requests from my RainMachine MAC address. The other device that was doing this in this log was a Roomba which is also 2.4GHz only. So that's why I say maybe this issue affects more than one device. I would appreciate if someone from Netgear would reach out to help make sure this issue gets fixed in a future firmware release.
I have tried manually assigning a 2.4GHz channel, tried a clean factory restart, etc. I have ethernet backhaul and its worked fine for me without issue.
[DHCP IP: 192.168.1.12] to MAC address 98:de:d0:12:26:00, Friday, May 11, 2018 02:07:08
[DHCP IP: 192.168.1.12] to MAC address 98:de:d0:12:26:00, Friday, May 11, 2018 00:59:02
[DHCP IP: 192.168.1.10] to MAC address e0:b9:4d:40:97:04, Friday, May 11, 2018 00:59:02
[DHCP IP: 192.168.1.12] to MAC address 98:de:d0:12:26:00, Friday, May 11, 2018 00:32:51
[DHCP IP: 192.168.1.12] to MAC address 98:de:d0:12:26:00, Friday, May 11, 2018 00:32:47
[DHCP IP: 192.168.1.12] to MAC address 98:de:d0:12:26:00, Friday, May 11, 2018 00:27:18
[DHCP IP: 192.168.1.12] to MAC address 98:de:d0:12:26:00, Friday, May 11, 2018 00:27:14
[DHCP IP: 192.168.1.12] to MAC address 98:de:d0:12:26:00, Friday, May 11, 2018 00:24:54
[DHCP IP: 192.168.1.12] to MAC address 98:de:d0:12:26:00, Friday, May 11, 2018 00:24:49
[DHCP IP: 192.168.1.12] to MAC address 98:de:d0:12:26:00, Friday, May 11, 2018 00:24:45
[DHCP IP: 192.168.1.12] to MAC address 98:de:d0:12:26:00, Friday, May 11, 2018 00:21:36
[DHCP IP: 192.168.1.12] to MAC address 98:de:d0:12:26:00, Friday, May 11, 2018 00:18:24
[DHCP IP: 192.168.1.12] to MAC address 98:de:d0:12:26:00, Friday, May 11, 2018 00:18:20
[DHCP IP: 192.168.1.12] to MAC address 98:de:d0:12:26:00, Friday, May 11, 2018 00:14:41
[DHCP IP: 192.168.1.12] to MAC address 98:de:d0:12:26:00, Friday, May 11, 2018 00:14:28
[DHCP IP: 192.168.1.12] to MAC address 98:de:d0:12:26:00, Friday, May 11, 2018 00:14:24
[DHCP IP: 192.168.1.12] to MAC address 98:de:d0:12:26:00, Friday, May 11, 2018 00:14:21
[DHCP IP: 192.168.1.12] to MAC address 98:de:d0:12:26:00, Friday, May 11, 2018 00:14:17
[DHCP IP: 192.168.1.12] to MAC address 98:de:d0:12:26:00, Friday, May 11, 2018 00:14:13
[DHCP IP: 192.168.1.12] to MAC address 98:de:d0:12:26:00, Friday, May 11, 2018 00:14:08
[DHCP IP: 192.168.1.12] to MAC address 98:de:d0:12:26:00, Friday, May 11, 2018 00:14:06
[DHCP IP: 192.168.1.12] to MAC address 98:de:d0:12:26:00, Friday, May 11, 2018 00:03:46
[DHCP IP: 192.168.1.12] to MAC address 98:de:d0:12:26:00, Friday, May 11, 2018 00:01:33
[DHCP IP: 192.168.1.12] to MAC address 98:de:d0:12:26:00, Friday, May 11, 2018 00:01:29
[DHCP IP: 192.168.1.12] to MAC address 98:de:d0:12:26:00, Thursday, May 10, 2018 23:52:18
[DHCP IP: 192.168.1.12] to MAC address 98:de:d0:12:26:00, Thursday, May 10, 2018 23:50:35
[DHCP IP: 192.168.1.12] to MAC address 98:de:d0:12:26:00, Thursday, May 10, 2018 23:46:46
[DHCP IP: 192.168.1.12] to MAC address 98:de:d0:12:26:00, Thursday, May 10, 2018 23:30:13
[DHCP IP: 192.168.1.12] to MAC address 98:de:d0:12:26:00, Thursday, May 10, 2018 23:27:57
[DHCP IP: 192.168.1.12] to MAC address 98:de:d0:12:26:00, Thursday, May 10, 2018 23:27:53
[DHCP IP: 192.168.1.12] to MAC address 98:de:d0:12:26:00, Thursday, May 10, 2018 23:00:01
[DHCP IP: 192.168.1.12] to MAC address 98:de:d0:12:26:00, Thursday, May 10, 2018 22:59:59
[DHCP IP: 192.168.1.12] to MAC address 98:de:d0:12:26:00, Thursday, May 10, 2018 22:55:15
[DHCP IP: 192.168.1.21] to MAC address 78:24:af:45:30:da, Thursday, May 10, 2018 22:55:12
[DHCP IP: 192.168.1.12] to MAC address 98:de:d0:12:26:00, Thursday, May 10, 2018 22:46:37
[DoS Attack: TCP/UDP Chargen] from source: 184.105.139.93, port 29977, Thursday, May 10, 2018 22:46:34
[DHCP IP: 192.168.1.12] to MAC address 98:de:d0:12:26:00, Thursday, May 10, 2018 21:33:01
[DoS Attack: RST Scan] from source: 66.85.80.245, port 1414, Thursday, May 10, 2018 21:32:58
[DHCP IP: 192.168.1.12] to MAC address 98:de:d0:12:26:00, Thursday, May 10, 2018 21:26:33
[DHCP IP: 192.168.1.22] to MAC address 00:05:cd:28:48:4e, Thursday, May 10, 2018 21:26:31
[DHCP IP: 192.168.1.12] to MAC address 98:de:d0:12:26:00, Thursday, May 10, 2018 21:21:47
[DoS Attack: RST Scan] from source: 74.91.117.227, port 443, Thursday, May 10, 2018 21:21:46
[DHCP IP: 192.168.1.12] to MAC address 98:de:d0:12:26:00, Thursday, May 10, 2018 21:01:17
[DHCP IP: 192.168.1.12] to MAC address 98:de:d0:12:26:00, Thursday, May 10, 2018 21:01:14
[DHCP IP: 192.168.1.12] to MAC address 98:de:d0:12:26:00, Thursday, May 10, 2018 21:01:12
[DHCP IP: 192.168.1.12] to MAC address 98:de:d0:12:26:00, Thursday, May 10, 2018 20:43:03
[DHCP IP: 192.168.1.14] to MAC address 80:a5:89:c2:dd:9e, Thursday, May 10, 2018 20:43:01
[DHCP IP: 192.168.1.12] to MAC address 98:de:d0:12:26:00, Thursday, May 10, 2018 20:42:42
[DHCP IP: 192.168.1.14] to MAC address 80:a5:89:c2:dd:9e, Thursday, May 10, 2018 20:42:41
[DHCP IP: 192.168.1.12] to MAC address 98:de:d0:12:26:00, Thursday, May 10, 2018 20:42:24
[DHCP IP: 192.168.1.14] to MAC address 80:a5:89:c2:dd:9e, Thursday, May 10, 2018 20:42:21
[DHCP IP: 192.168.1.12] to MAC address 98:de:d0:12:26:00, Thursday, May 10, 2018 20:42:02
[DHCP IP: 192.168.1.14] to MAC address 80:a5:89:c2:dd:9e, Thursday, May 10, 2018 20:42:01
[DHCP IP: 192.168.1.12] to MAC address 98:de:d0:12:26:00, Thursday, May 10, 2018 20:41:43
[DHCP IP: 192.168.1.14] to MAC address 80:a5:89:c2:dd:9e, Thursday, May 10, 2018 20:41:41
[DHCP IP: 192.168.1.12] to MAC address 98:de:d0:12:26:00, Thursday, May 10, 2018 20:41:24
[DHCP IP: 192.168.1.14] to MAC address 80:a5:89:c2:dd:9e, Thursday, May 10, 2018 20:41:21
[DHCP IP: 192.168.1.12] to MAC address 98:de:d0:12:26:00, Thursday, May 10, 2018 20:41:03
[DHCP IP: 192.168.1.14] to MAC address 80:a5:89:c2:dd:9e, Thursday, May 10, 2018 20:41:01
[DHCP IP: 192.168.1.12] to MAC address 98:de:d0:12:26:00, Thursday, May 10, 2018 20:40:42
[DHCP IP: 192.168.1.14] to MAC address 80:a5:89:c2:dd:9e, Thursday, May 10, 2018 20:40:41
[DHCP IP: 192.168.1.12] to MAC address 98:de:d0:12:26:00, Thursday, May 10, 2018 20:40:23
[DHCP IP: 192.168.1.14] to MAC address 80:a5:89:c2:dd:9e, Thursday, May 10, 2018 20:40:21
[DHCP IP: 192.168.1.12] to MAC address 98:de:d0:12:26:00, Thursday, May 10, 2018 20:40:02
[DHCP IP: 192.168.1.14] to MAC address 80:a5:89:c2:dd:9e, Thursday, May 10, 2018 20:40:01
[DHCP IP: 192.168.1.12] to MAC address 98:de:d0:12:26:00, Thursday, May 10, 2018 20:39:44
[DHCP IP: 192.168.1.14] to MAC address 80:a5:89:c2:dd:9e, Thursday, May 10, 2018 20:39:41
[DHCP IP: 192.168.1.12] to MAC address 98:de:d0:12:26:00, Thursday, May 10, 2018 20:39:22
[DHCP IP: 192.168.1.14] to MAC address 80:a5:89:c2:dd:9e, Thursday, May 10, 2018 20:39:21
[DHCP IP: 192.168.1.12] to MAC address 98:de:d0:12:26:00, Thursday, May 10, 2018 20:39:04
[DHCP IP: 192.168.1.14] to MAC address 80:a5:89:c2:dd:9e, Thursday, May 10, 2018 20:39:01
[DHCP IP: 192.168.1.12] to MAC address 98:de:d0:12:26:00, Thursday, May 10, 2018 20:38:42
[DHCP IP: 192.168.1.14] to MAC address 80:a5:89:c2:dd:9e, Thursday, May 10, 2018 20:38:41
[DHCP IP: 192.168.1.12] to MAC address 98:de:d0:12:26:00, Thursday, May 10, 2018 20:38:24
[DHCP IP: 192.168.1.14] to MAC address 80:a5:89:c2:dd:9e, Thursday, May 10, 2018 20:38:21
[DHCP IP: 192.168.1.12] to MAC address 98:de:d0:12:26:00, Thursday, May 10, 2018 20:38:02
[DHCP IP: 192.168.1.14] to MAC address 80:a5:89:c2:dd:9e, Thursday, May 10, 2018 20:38:01
[DHCP IP: 192.168.1.12] to MAC address 98:de:d0:12:26:00, Thursday, May 10, 2018 20:37:44
[DHCP IP: 192.168.1.14] to MAC address 80:a5:89:c2:dd:9e, Thursday, May 10, 2018 20:37:41
[DHCP IP: 192.168.1.12] to MAC address 98:de:d0:12:26:00, Thursday, May 10, 2018 20:37:22
[DHCP IP: 192.168.1.14] to MAC address 80:a5:89:c2:dd:9e, Thursday, May 10, 2018 20:37:21
[DHCP IP: 192.168.1.12] to MAC address 98:de:d0:12:26:00, Thursday, May 10, 2018 20:37:04
[DHCP IP: 192.168.1.14] to MAC address 80:a5:89:c2:dd:9e, Thursday, May 10, 2018 20:37:01
[DHCP IP: 192.168.1.12] to MAC address 98:de:d0:12:26:00, Thursday, May 10, 2018 20:36:42
[DHCP IP: 192.168.1.14] to MAC address 80:a5:89:c2:dd:9e, Thursday, May 10, 2018 20:36:41
[DHCP IP: 192.168.1.12] to MAC address 98:de:d0:12:26:00, Thursday, May 10, 2018 20:36:24
[DHCP IP: 192.168.1.14] to MAC address 80:a5:89:c2:dd:9e, Thursday, May 10, 2018 20:36:21
[DHCP IP: 192.168.1.12] to MAC address 98:de:d0:12:26:00, Thursday, May 10, 2018 20:36:02
[DHCP IP: 192.168.1.14] to MAC address 80:a5:89:c2:dd:9e, Thursday, May 10, 2018 20:36:01
[DHCP IP: 192.168.1.12] to MAC address 98:de:d0:12:26:00, Thursday, May 10, 2018 20:35:44
[DHCP IP: 192.168.1.14] to MAC address 80:a5:89:c2:dd:9e, Thursday, May 10, 2018 20:35:41
[DHCP IP: 192.168.1.12] to MAC address 98:de:d0:12:26:00, Thursday, May 10, 2018 20:35:23
[DHCP IP: 192.168.1.14] to MAC address 80:a5:89:c2:dd:9e, Thursday, May 10, 2018 20:35:21
[DHCP IP: 192.168.1.12] to MAC address 98:de:d0:12:26:00, Thursday, May 10, 2018 20:35:04
[DHCP IP: 192.168.1.14] to MAC address 80:a5:89:c2:dd:9e, Thursday, May 10, 2018 20:35:01
[DHCP IP: 192.168.1.12] to MAC address 98:de:d0:12:26:00, Thursday, May 10, 2018 20:34:42
[DHCP IP: 192.168.1.14] to MAC address 80:a5:89:c2:dd:9e, Thursday, May 10, 2018 20:34:41
[DHCP IP: 192.168.1.12] to MAC address 98:de:d0:12:26:00, Thursday, May 10, 2018 20:34:24
[DHCP IP: 192.168.1.14] to MAC address 80:a5:89:c2:dd:9e, Thursday, May 10, 2018 20:34:21
[DHCP IP: 192.168.1.12] to MAC address 98:de:d0:12:26:00, Thursday, May 10, 2018 20:34:03
[DHCP IP: 192.168.1.14] to MAC address 80:a5:89:c2:dd:9e, Thursday, May 10, 2018 20:34:01
[DHCP IP: 192.168.1.12] to MAC address 98:de:d0:12:26:00, Thursday, May 10, 2018 20:33:44
[DHCP IP: 192.168.1.14] to MAC address 80:a5:89:c2:dd:9e, Thursday, May 10, 2018 20:33:41
[DHCP IP: 192.168.1.12] to MAC address 98:de:d0:12:26:00, Thursday, May 10, 2018 20:33:22
[DHCP IP: 192.168.1.14] to MAC address 80:a5:89:c2:dd:9e, Thursday, May 10, 2018 20:33:21
[DHCP IP: 192.168.1.12] to MAC address 98:de:d0:12:26:00, Thursday, May 10, 2018 20:33:03
Message 47 of 114
cheshbr
Apprentice
I have installed the temporary FW version  2.1.4.10_0430_dbg, links below, which fixed my system.  I have several Lifx globes that became unresponsive in the two upgrades since FW V2earlier FW upgrades.1.2.18.
After installing the FW linked below, my system is now sttable and working as it should, including wired backhaul
Note.  These links are for the RBR50 and RBS50.
RBR50:
Download link: http://files.netgear-support.com/go/?a=d&i=EjBr71Dbxr
RBS50:
Download link: http://files.netgear-support.com/go/?a=d&i=L2VwBr87ac
Firmware version: 2.1.4.10_0430_dbg
Message 48 of 114
Sdiver2489
Apprentice
RBR50:
RBS50:
Hm...this sounds promising...where did this firmware come from? I would definitely like to try it but just want some input from Netgear on what this was designed to fix. If it has something to do with connectivity from 2.4GHz devices then I am extremely hopeful this will fix my last issue!
Message 49 of 114
cheshbr
Apprentice
Firmware version: 2.1.4.10_0430_dbg came from Netgear.  I was a beta tester, and after my success, and no doubt others, Netgear released it widely.
Have a look at these websites
https://9to5mac.com/2018/05/08/netgear-orbi-homekit-error-no-response/
https://appleinsider.com/articles/18/05/09/netgear-offers-hotfix-for-orbi-routers-encountering-apple...
http://machash.com/9to5mac/245315/netgear-releases-special-firmware-to-address-homekit-issues-with-o...
Message 50 of 114
Top Contributors
Discussion stats
Announcements
Orbi WiFi 7
