Orbi WiFi 7 RBE973
Reply
OrbiOSV2.3.1.48 + Homekit
picsou123
Bonjour
j ai un orbi rbr50 avec le firmware V2.3.1.48 , et homekit ne fonctionne pas ( meme avec le precedent firmware cela ne fonctionnait pas).
Ma configuration :
- livebox ( wifi desactivé).
- routeur orbirbr50 branche en ethernet en mode routeur.
- satellite avec le firmware V2.3.1.48
- detecteur eve room a distance proche du satellite
Des que je m eloigne du satelitte , ou en 4G dans l application Maison les appareil sont sans reponse.
y a til une solution? merci
Message 1 of 11
Guru
Re: OrbiOSV2.3.1.48 + Homekit
en anglais s'il vous plaît
@picsou123 wrote:
Bonjour
Ma configuration :
Message 2 of 11
angr
Star
(I thought this was an English forum?)
Anyway, I can confirm that the .48-firmware also broke my HomeKit setup that's been running stable for a long time with many differen FW versions.
I've had issues way in the past but they were fixed a long time ago, but the issue seems to unfortunately have resurfaced again with V2.3.1.48.  Besides this issue the rest seems to work just fine. Hoping for a quick fix!
Message 3 of 11
Guru
This is a English forum. You posted in French.
Try a factory reset and setup from scratch to see if this solves this.
What FW version were you using when Homekit was working?
Message 4 of 11
angr
Star
No I didn't. I replied to a post in French. Notice the difference.
I prefer to wait until Netgear fixes it. Performing a factory reset and setting up things from scratch will take me at least a day, probably longer. I think the vendor needs to do their part first to resolve this. HomeKit has worked fine on most FW versions up until now with .48.
Message 5 of 11
Guru
Yes it was in french. We requested English text. Thanks.
A factory reset would be needed to see if this fixes the issue. There maybe some lingering code or mis-configuration from the last FW version that was loaded that maybe inhibiting correct operation. We havn't seen any others with Homekit issues as of yet so maybe your the first or the only one with this problem.
You can file a support ticket for additional help and let NG now about this. They may not be aware and may not fix it if they don't know about it.
https://www.netgear.com/mynetgear/registration/login.aspx
Good Luck though.
Message 6 of 11
picsou123
hello
i did a reset but it did not fix the problem
Message 7 of 11
Guru
Please contact NG support regarding this.
@picsou123 wrote:
hello
Message 8 of 11
angr
Star
An upgrade to V2.3.1.60 resolved my HomeKit issues again. As expected, no resets required. This was all Orbi FW related.
I can see by this thread that they were also fully aware of this being a problem;
https://community.netgear.com/t5/Orbi/OrbiOS-2-1-4-Homekit/m-p/1565698
Model: RBR50|Orbi AC3000 Tri-band WiFi Router
Message 9 of 11
Guru
Thanks for letting us know v60 works for you.
Enjoy. Smiley Wink
Message 10 of 11
GadgetVirtuoso2
Apprentice
Even with .60 I continue to see HomeKit issues. It first started with my Wemo devices but is not affecting the new Phillips Hue kit I recently purchased.
Message 11 of 11
Top Contributors
Discussion stats
  • 10 replies
  • 2626 views
  • 0 kudos
  • 4 in conversation
Announcements
Orbi WiFi 7
