Reply
Highlighted
Tutor
Orbie guest network - no internet!
When selecting the guest may view the internal network, the internet works. But if unselecting (which actually should be) there is no internet connection :-(
Router-Firmware V1.8.0.6
Model: Orbi High-Performance AC3000 Tri-Band WiFi System (RBK50)
Message 1 of 6
Highlighted
Re: Orbie guest network - no internet!
I am going to take a stab at it and guess that you are using the Orbi in Access Point mode.  I am, and I noted the same behavior.
BTW, mine are new and I noted that the main unit updated to the new firmware but the sat's wouldn't.
The firmware on the Sat's was 1.2 something.  I had to manually update the Sat's to 1.5.0.12.  When that was complete the host unit updated the Sat's to the new 1.8.0.6 as expected.  It is my supposition that the Sat's need a firmware update to 1.4 or greater before the Sat's can be updated by the host Orbi.  The updates have been working just fine (Access Point mode) on the Host and Sat's
Regards
Message 2 of 6
Highlighted
Tutor
Yes, the Orbis are in Access Point mode. Forgot to mention that.
Message 3 of 6
Highlighted
Virtuoso
Before I bother with the latest update, is it correct that guest in AP mode still doesn't work?  If not, going to sit this update out.
Rodney
Message 4 of 6
Highlighted
I am guessing from prior experience, that turning off access to the local network will prevent your traffic from reaching the internet gateway (router) where your broadband is provisioned..  Hence, turning off guest access to the local network will not allow trafic to the gateway to work.  I have not investigated whether or not any port forwarding or DMZ is available.  I doubt it.
Regards
Message 5 of 6
Highlighted
Sorry, I should have mentioned that this behavior is a side result of using the Orbi as an access point.  It is not an issue if used as a router.  And the update did not change this situation.  You can send a support request in, but I think you are going to get essentially the same answer.
Regards
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 2442 views
  • 2 kudos
  • 3 in conversation
Announcements
