Reply
Orbilogin doesn't work - certificate?
wyncdavies
Tutor
I can no longer log into my RBR50 system with orbilogin.com.  I get a page that says I'm not on the wifi (which I am).  I have tried three different browsers (Chrome, Safari and Edge) to no avail.  It's something to do with the certificate of the site but I don't know how to correct it.
Any ideas?
Model: RBR50|Orbi AC3000 Tri-band WiFi Router
Message 1 of 13
CrimpOn
Guru
Re: Orbilogin doesn't work - certificate?
I always use the Orbi IP address, which in most cases is 192.168.1.1
Modern browsers complain about the Orbi SSL certificate being "Self Signed" the first time I open it.  Just locate the place in tiny type that says, "go to this page anyway dammit".
I love my Orbi.
Message 2 of 13
wyncdavies
Tutor
I get the same error when using the IP address.
Message 3 of 13
CrimpOn
Guru
Is it correct to assume that other networking activities function as they should? (email, web browsing other sites,etc.)
On Windows, I would open a command window and attempt to ping the router at its IP address ( i.e. in my case ping 192.168.1.1)
Does the Mac have a similar capability?
I love my Orbi.
Message 4 of 13
BillYoung
Luminary
wyncdavies:
Silly question time:  are you connected to the correct network?  If you are connected to a guest network, orbilogin.com and 10.0.0.1 (or 192.168.1.1) will not work.
Hope that helps.
BillYoung
Message 5 of 13
wyncdavies
Tutor
I can ping the router, no problem.
Message 6 of 13
wyncdavies
Tutor
I'm on the right network.
Message 7 of 13
Guru
Please provide a screen capture of what your seeing on the web page. Please use the Choose File button to attach this to your next post.
My Setup ISP SparkLight | Internet Cable 1000↓/50↑ CAX80 Modem Mode |  Wifi Router RBK953 (Router Mode) 2.5Gb Wired Backhaul | Switches NG GS105/8, GS308v3, GS110MX and XS505M | XR1000 (Router Mode) and RBK853 AP Mode  |
Additional NG HW: C7800/CAX80/CM1100/CM1200/CM2000, Orbi: CBK40, CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: MK63, R7000, R7800, R7960P, R8000, R8500, RAXE500, RAX50, XR450, EX7500/EX7700
Message 8 of 13
wyncdavies
Tutor
Message 9 of 13
wyncdavies
Tutor
Message 10 of 13
wyncdavies
Tutor
Message 11 of 13
wyncdavies
Tutor
Message 12 of 13
Guru
Ok, seen this before on Safari. New handling behaviors of Safari.
What happens if you entering your OSX user account password when asked for PW?
Message 13 of 13
Top Contributors
Discussion stats
  • 12 replies
  • 942 views
  • 1 kudo
  • 4 in conversation
Announcements
Orbi WiFi 6E
