- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Orbo Satellite blue light keeps turning on then staying on for a while
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbo Satellite blue light keeps turning on then staying on for a while
Welcome to the community, @jimcall37
What's the model of your Orbi?
Try to turn it off for about two minutes by pushing the on/off button at the back of it then turn it back on.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi. The sattelite is the RBS50. I have tried multiple times turning it off, waiting, then turning it back on.
- Mark as New
- Bookmark
- Subscribe
- Permalink
How long have you had the kit?
When did you start experiencing that issue?
Have you tried moving it closer to the main router?
I suggest for you to reset it with a paper clip once again and if that didn't work register the kit in order to log a case.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi. I have owned the kit for a little over four months. The issue has been going on consistantly for about a month. I have reset it with a paper clip, but I certainly could try that again. The first time I reset it I had moved it much closer to the router.
- Mark as New
- Bookmark
- Subscribe
- Permalink
You can also try unchecking the "Enable Daisy-Chain Topology" box in the web GUI under Advanced>>Advanced Setup>>Wireless Settings.
When my system auto-upgraded to the 2.0.0.74 firmware, I discovered that box was checked and I believe it is the default. Regardless, the LED on one of my satellites was cycling from OFF to BLUE to OFF as it randomly connected to the other satellite and the router and back to the satellite. Unchecking the "Enable Daisy-Chain Topology" box resolved that issue immediately.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi. I appreciate your suggestion, but unfortunately it didn't work for my satellite. So, it looks like I'm at a loss as to how to fix it.
