Discussion stats
  • 10 replies
  • 1402 views
  • 1 kudo
  • 3 in conversation
Announcements
Top Contributors
Reply
Highlighted
Tutor
Orib RBK40 Unresponsive, Reset not working
Hi
I recently had to unplug my Orbi router and satellite. When I plugged my Router back in, I noticed that the LED on top was not flashing at all and that it seemed to not see my ISP's modem/internet connection. There was no wifi signal either (SSID did not appear on wireless devices).
I then tried to perform a hard reset, following the standard procedure, but the power LED just stays solid green, it does not kick over to amber, indicating a reset. I have also tried the 30-30-30 method to reset, which did not work.
When I plug my laptop directly into the router, using an IP that should be on the same subnet as the router, my laptop's ethernet port shows it is "disconnected". I cannot connect to the router to try a TFTP firmware upload to try and work around this issue.
As far as I can tell, the router is completely bricked. I was surprised to see I had to pay for support access, but coughed up the money. After being on hold for 45 minutes, the lady told me I had the "wrong concern group" and that she doesn't support ORBI routers. She put me on hold saying she would transfer me to someone who could help. That was over an hour ago, and I am still on hold with no indication of what is happening (if anything).
I really need some help Netgear - this is pretty bad customer support.
Model: RBK40| Orbi AC2200 WiFi System
Message 1 of 11
Accepted Solutions
Highlighted
Tutor
Re: Orib RBK40 Unresponsive, Reset not working
Just to close this out - I was eventually able to get Netgear support on the phone and initiated the RMA process - the router is a brick, as suspected.
Message 8 of 11
All Replies
Highlighted
Guru
Are you holding the reset button in until the top LED on the router turns from white to amber or yellowish color?
the 30-30-30 isn't supported on NG routers anymore I believe...
Try this?
https://community.netgear.com/t5/Nighthawk-WiFi-Routers/SOLVED-Steps-for-debrick-unresponsive-R7000-...
Besure to use the Windows built in TFTP program, not the one suggested by NG. It's doesn't work.
My Setup (Cable 900Mbps/50Mbps)>CAX80>RBK853 v3.1.15.32(Router Mode)
Additional NG HW: C7800/CM1100/CM1200, Orbi CBK40, RBK50, R7800, R7960P,
EX7500/EX7700, XR450 and WNHDE111
Message 2 of 11
Highlighted
Tutor
Thanks for you reply
My original post mentions I did try a regular reset first, and it does not work, the light stays green as mentioned. I am certainly making contact with the reset button as I can feel it click down.
At no time does the LED on the top of the unit come on.
Your link details the TFTP procedure to try and upload new firmware. When I plug into any LAN port on the Orbi, the connection is not recognized (i.e. the laptop which is connected to the LAN port shows its eternet port as "disconnected") It is impossible to TFTP to the device.
Message 3 of 11
Highlighted
Guru
If the top LED isn't coming on amber or any color, I believe the unit is bad.
You'll need to make contact with NG support and check on a RMA.
Message 4 of 11
Highlighted
Tutor
Thanks for your reply - I agree. I am having trouble actually talking to someone at Netgear, as mentioned in my original post. I spent almost 2 hours mostly on hold this morning. Is there a specific number for Orbi support? Details of my experience are in my original post.
Message 5 of 11
Highlighted
Guru
Lets try a forum moderator.
@DarrenM
Message 6 of 11
Highlighted
NETGEAR Moderator
Saltin I have sent you a PM.
DarrenM
Message 7 of 11
Highlighted
Tutor
Message 8 of 11
Highlighted
Guru
Hope the the RMA works for you. Let us know how it goes.
Message 9 of 11
Highlighted
Tutor
RMA complete and issue is fixed -the unit I recieved works fine.
Message 10 of 11
Highlighted
Guru
Glad the new units works. Enjoy.
Smiley Wink
Message 11 of 11
