Orbi WiFi 7 RBE973
Reply
Oriblogin.net saying my router is not internet connected
Mohnkern
Follower
I've had an Orbi RBR 50 with three satellites for just over two years.  Its connected behind a FioS router (hardwired).
Today I started having all sorts of weird networking issues.  I ended up rebooting the router and satellites.  It looked like everything was "mostly" fine after the reboot.  (It had been several months since a reboot).
However, I'm seeing two problems.
First, I have one Amazon Echo, that when it tries to connect, says that the Router doesn't have Internet access.  I assume this is due to a block that some how kicked in at the router.  (I've seen this before).
So, I went to https://orbilogin.net and it says that I'm not connected to my Orbi network, and I am.  I've confirmed it. and I have internet access.
IThe same is true for https://routerlogin.net.
If I go to https://routerlogin.net on my ipad, I can sign in, and it tells me my Orbi Satellite Connection is up and running.
I double check the wifi connection on my ipad, and it says its connected, but no internet connection.
Oddly the guest network has disappeared as well.
I'm really mistified how to proceed at this point.
Model: RBR50|Orbi AC3000 Tri-band WiFi Router
Message 1 of 3
Guru
Re: Oriblogin.net saying my router is not internet connected
If the ISP modem/ONT has a built in router, This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Message 2 of 3
CrimpOn
Guru
The default Orbi web site is not encrypted, so the URL is http://orbilogin.net (no "S").  This is partly browser dependent.  Some browsers 'force' the https when the user enters it and others will look for both types.
You mention reboot.  That means power off and then power back on, correct?  (Not a Factory Reset, which erases all user settings.)
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 433 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
