- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Outdoor orbi
- Mark as New
- Bookmark
- Subscribe
- Permalink
I just added the outdoor orbi. Everything works great but after a while during the day the connection to the internet is dropped. I then reboot the router and it stays on a while then I have to do it again. It’s happened once or twice/day. The firmware versions are the same for the router orbi and 2 sats but the rbs50y has different firmware. All firmware is the latest according to the orbilogin page. I thought everything had to have the same fw
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Outdoor orbi
The latest SW for RBS50Y is 2.2.1.204 according to the Support web page.
- When you get internet disconnected, do you see that the connection between satellite and router is disconnected in the web GUI or app?
- Is the RBS50Y nearest to the router or to one of the satellites? if closer to one of the other satellites it can be good to have "Daisy Chain" activated. Anyways it seems that for 2.2.1.210 you have to have Daisy Chain on so please make sure it's on.
- Please make a wifi scan and check which channels are being used for the backhaul and check if neighbors are using the same channels. It worths checking the backhaul channels for some time and see what channels were used when the RBS50Y is working well and what the backhaul channel will be when it disconnects.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Outdoor orbi
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Outdoor orbi
- Mark as New
- Bookmark
- Subscribe
- Permalink
