- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Outside WiFi cams ignoring sats & going to router?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Outside WiFi cams ignoring sats & going to router?
Alot of signal handling is done at the camera as well. It all depend on what they are set up and configured for in handling wifi signals.
What you might try is to reduce the power levels on the router from 100% to say 75 or 50% and see if the cameras connect differently. This may impact signals between the router and satellites as well.
Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.
MIMO, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
- Mark as New
- Bookmark
- Subscribe
- Permalink
Where do I go to “lower the strength”?
What the best way to determine which 5ghz isn’t being used? It’s set to a number like 48, there was like 4 choices to pick from.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Adanced Tab/Advanced Settings/Wireless Settings
Try them all. However use a wifi scanner to see other neighbors near by to see what there using. Should matter for cameras. I presume they are only using 2.4Ghz?
- Mark as New
- Bookmark
- Subscribe
- Permalink
My cameras support both 2.4/5ghz, which prob makes it even more confusing for them with Orbi. I wish I could force connect them to 2.4ghz only & specific sat per camera.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
If your ISP doesn't have native IPv6 support, leave it disabled.
https://itunes.apple.com/us/app/network-analyzer-lite-wifi/id562315041?mt=8 Free
http://www.nirsoft.net/utils/wifi_information_view.html Free
https://www.acrylicwifi.com/en/wlan-software/wlan-scanner-acrylic-wifi-free/ Free
https://lizardsystems.com/wi-fi-scanner/screenshots.php
http://nutsaboutnets.com
http://www.metageek.com/products/inssider/
NOTE: InSSIDer is no longer free.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Let us know how it goes...
- Mark as New
- Bookmark
- Subscribe
- Permalink
Seems that your cameras do not support roaming and they just connect to the first basestation that becomes available (which is the router) and never makes measurements to decide if there are better basestations to roam to. Check if the cameras support (802.11k/802.11v/802.11r)
- Try switching off a camera and then switch it on and see where it will connect.
- Try switching off the router for few seconds and then on to see if the cameras will decide to change to the satellites.
It can also be that the cameras don't like the 5GHz channel that you set in the router (because it's used by neighbours) and goes for the 2.4 GHz channel.
- Try changing the 5 GHz to another channel as suggested by FURRYe38.
- Try also to reduce the power of only the 2.4GHz channels to very low value and see if the cameras will behave differently.
- Mark as New
- Bookmark
- Subscribe
- Permalink
All it says on data sheet around WiFi: 2.4ghz/5ghz, B,G,N,AC.
I lowered power on both 2.4/5ghz, so let me put the 5ghz back to 100%.
Thx for the advice, will be trying all suggestions, not giving up easily... I was excited to try Orbi, so I did expect some placement & settings tweaking would be required. Will keep you all posted.
- Mark as New
- Bookmark
- Subscribe
- Permalink
So far entire day since then, all is working good!
I’ll experiment with adding back roaming for few days... & then adding back beamforming, then mimmo, etc.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@Adrian97c wrote:
Ok I’ll check those out after work today... I’m not sure what xfinity blast has v6 support or not. Thx for the info so far!
Comcast has supported IPv6 for years and it works fine.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
IPv6 allows for different way to connect to the Orbi and get internet access. It's the next IP addressing scheme to come out. Not all ISPs support it natively yet. Not all devices support IPv6 address protocols either. You can test with it enabled or disabled. If your cameras don't support it, they won't use it so don't worry about them.
https://en.wikipedia.org/wiki/IPv6
@Adrian97c wrote:
What does it exactly do? It was off in my Orbi settings by default.. what would I expect to see by enabling the option?
