- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
PROBLEMS ACTIVATING SERVICE CONTRACT TO ACTIVATE ROUTER RBR20
- Mark as New
- Bookmark
- Subscribe
- Permalink
I'M HAVING A PROBLEM GETTING MY ROUTER ACTIVATED SO I CAN GET THE KEY.
HELP. I THOUGHT GETTING THIS ROUTER WAS GOING TO BE AN ASSET, BUT, IT IS TURNING INTO A NIGHTMARE.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: PROBLEMS ACTIVATING SERVICE CONTRACT TO ACTIVATE ROUTER RBR20
I'm not sure exactly what you have going on here. What key do you need? the RBR20 should connect to a modem/gateway device that your isp helps you setup. Once the gateway is setup, then you hook the rbr20 to it and go through setup.
What modem/gateway are you using?
Who's your ISP?
What steps have you taken so far so we know where you're getting stuck.
here's the manual for the RBR20 support site.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I actually took the time to go back to my products page, the one I registered with the RBR20. The page that I was using was the one about the registration, showing the serial number, etc. Not only was I unable to download the supposedly needed ones, I was taken to another window to extend the service. I was very upset and disappointed about what it was happening.
I’ve always had hi regards for Netgear products. That was the reason in the first place now? I purchased the ORBI RBR20 router and satellite.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Even what you have said doesn't make much sense.
If you're wanting to upgrade the firmware, you can manually do it through the device support page.
https://www.netgear.com/support/product/RBR20.aspx
The downloads button has the firmware and the documents page has the manual with how to manually update. Its fairly simple to do. And doesn't require going through the extended service at all. Just the standard product support page.
If you get the device online, it does do automatically update.
You didn't say what modem you use or if you could get online with the modem directly connected.
