Magnolialilyave's avatar
Oct 16, 2019
PS4 having upload speed issues on Orbi RBS50
My PlayStation 4 is having issues with it's upload speed. I have AT&T Fiber and I'm supposed to get 1000mbps. The download speed ranges from 250-300mbps but the upload speed will not go above 2mbps which is causing my games to lag. No one else in the house seems to have trouble with buffering. I had the AT&T technican come out and test it three different ways and he couldn't get the upload speed to change. I even went as far as to buy a new PlayStation 4 Pro and the same thing is still happening. Anyone else have any similar issues?
1 Reply
  • FURRYe38's avatar
    Is the PS cosole wired or wireless connected to the RBR?
    Do you get to spec speeds with other devices like a wired PC connected to the RBR?
    What is the distance between the router and satellite(s)? 30 feet is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
    Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
