- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Painting outdoor satellite
- Mark as New
- Bookmark
- Subscribe
- Permalink
Can you paint an outdoor orbi satellite to blend in with the house?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Painting outdoor satellite
WiFi signals penetrate interior walls consisting of two sheets of gypsum board with (usually latex) paint on both sides, maybe more than one coat plus primer. The signal already penetrates the plastic case of the satellite. In my house, they go through several walls. To reach your satellite, signals may also penetrate brick, wood, or stucco.
My guess is that (non-metallic) paint on the side of the Orbi satellite facing outward will reduce signal strength and coverage, but probably not enough to measure. And, if you find the satellite no longer works correctly, paint should peal off the slick plastic pretty easily.
I think people would appreciate knowing how it turns out for you.
- Mark as New
- Bookmark
- Subscribe
- Permalink
If you paint, i would use a spray paint. Just understand that if you do paint the unit, this may void warranty as if the unit would need to be returned due to a future problem, I don't think NG would accept it back due to a change in color and paint job.
