- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Pandora won't stream
- Mark as New
- Bookmark
- Subscribe
- Permalink
I just installed an Orbi system with 2 satellites yesterday. Now when I try to play Pandora via WiFi, it queues up a song, never plays and instead cycles to the next. ad infinitum. I've already rebooted everything including my AT&T 210 modem (gigabit fiber). It will stream fine if I turn the AT&T wifi back on and turn off Orbi, anyone seen this problem.
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Pandora won't stream
Modem Combo Units:
This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
1. Configure the modem for transparent bridge mode. Then use the Orbi router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
@tripleg wrote:I just installed an Orbi system with 2 satellites yesterday. Now when I try to play Pandora via WiFi, it queues up a song, never plays and instead cycles to the next. ad infinitum. I've already rebooted everything including my AT&T 210 modem (gigabit fiber). It will stream fine if I turn the AT&T wifi back on and turn off Orbi, anyone seen this problem.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I'm not able to use IP passthru as I have that already dedicated to another system that requires a WAN IP. Therefore if this is the only way it will work then I will need to return this product as it won't work
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
thankyou after changing to AP mode it's working
- Mark as New
- Bookmark
- Subscribe
- Permalink
Your ISP modem is the issue with already having a router online so two routers causes problems. DMZ or IP Passthrough fixes this however since you have that for something else, AP mode is the fix for your configuration..
Enjoy.
