- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Parental / Device Controls
- Mark as New
- Bookmark
- Subscribe
- Permalink
Will this device include Parental / device controls in the backend? A router without it is useless in our house, as during homework times we have to control who uses the internet at what times for the kids to keep them focused on tasks. Is there a place we can view a sample of the backend user interface?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Parental / Device Controls
Hello jvanstone12
Yes the Orbi will have parental controls. And we not have a place to view the GUI yet but we should have a manual soon to look at that.
DarrenM
- Mark as New
- Bookmark
- Subscribe
- Permalink
the question is are you talking about parental controls or just acces control of firewall rules
the actual parental control is set by opendns ands sort of works but is easily bypassed if the kids know how and your not actually watching them
if however you just want to block internet access by time based schedule its already available
go to the gui and click on the advanced tab
select security and schedule
first ensure the Time zone is set correctly for your region etc
then
set the time you want the internet blocked
next go to security / access control
turn on access control
select which devices you want blocked
click the block button and then click apply
this should block the devices at the required time from accessing the internet
pete
- Mark as New
- Bookmark
- Subscribe
- Permalink
Peteytesting:
You said " if however you just want to block internet access by time based schedule its already available
go to the gui and click on the advanced tab"
Which GUI?
Thanks,
Andreapdx
- Mark as New
- Bookmark
- Subscribe
- Permalink
Did you get an answer to your question? I want the same functionality but can't figure out a way to do it.
Thanks.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Sorry,
I ended up purchasing a Linksys AC3200 router instead, so I'm not able to answer your question. With the Linksys I am able to login using the Android app and set usage times per device.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks for the info. I might end up returning the ORBI and doing the same thing. Parental Controls and access time control should be standard in a home router and using OpenDNS just is not on par with what is out there. Apple has had this feature for a decade...sorry they are leaving the wifi router market.
