Orbi WiFi 7 RBE973
Reply
Parental controls not effective
Gilesmanners
Hi - I have enabled Parental Controls at a Low level, and yet I find that a search on free porn is able to connect and load to any of the sites that appear. So, clearly not at all effective. I have checked on several devices, rebooted the router, and I am pretty sure that I am not logged into the bypass account. So  - anything else I can do?
Many thanks
Model: RBR50| Orbi AC3000 Tri-band WiFi (Router Only)
Message 1 of 2
DarrenM
Sr. NETGEAR Moderator
Re: Parental controls not effective
Have you tried to set it to moderate and see a different result? You can also try to use Disney circle parental controls if you have firmware 2.1 or higher on your system.
DarrenM
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 390 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
