Orbi WiFi 7 RBE973
Reply
Password not accepted
Gellie
New Orbi set up. In the house everything works fine. Problem is when I go out in my yard (approx 25-30 ft from statelite) I loose internet connection on my Iphone. I see my Orbi network(strong single),click on it, and it ask me for password. When I put it in it says incorrect password. when I re enter my house it automatically connects. I think my Iphone is trying to connect with on of my satelites? Why wont it let me connect outside with the correct password? TIA
Model: RBK50| Orbi AC3000 High-Performance Tri-Band WiFi System
Message 1 of 3
Guru
Re: Password not accepted
Use the forget this network on the iphone, then back out then try to rejoin again. Sometimes the prior network caches and config needs to be cleared on the iphone.
Works inside the home right?
Message 2 of 3
Gellie
Thx, I have tried setting th network settings on my Iphone. No help. But i'll try forgetting network to see if that helps. Yes work inside.
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 609 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
