- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Ping
- Mark as New
- Bookmark
- Subscribe
- Permalink
Ping
Hello I recently bought the orbi router since my ping has been skyrocketing in some games. Normally it stays below 30 but then goes up to 250 for about 20 minutes and then comes down. Please help with this issue it has been occuring for a few months now with no hope.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Ping
What FW is currently loaded?
Is the Orbi system operating in Router or AP mode?
What gaming devices do you use?
Gaming devices wired or wireless connected?
What other devices do you have connected to the orbi?
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.
What WPA security modes are you using?
Try enabling WMM, Beamforming and MIMO. Under Advanced Tab/Advanced Settings/Wireless Settings
Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s)
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Ping
@fennypennyy wrote:Hello I recently bought the orbi router since my ping has been skyrocketing in some games. Normally it stays below 30 but then goes up to 250 for about 20 minutes and then comes down. Please help with this issue it has been occuring for a few months now with no hope.
The ping was high for months before installing the Orbi, and shows the same behavior after installing the Orbi?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Ping
what modem are you using? Firmware on it?
Signal/configuration page for your modem showing connections and logs?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Ping
Any progress on this?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Ping
The router was high ever since I started to try home wifi routers but before that I had a nighthawk which had no issues the only reason I bought this new one was because of the range it covered
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Ping
What FW is currently loaded? V2.3.1.58
What is the Mfr and model# of the ISP modem the NG router is connected too? Arris and TM822A
Is the Orbi system operating in Router or AP mode? Router
What gaming devices do you use? Nintendo switch and PC
Gaming devices wired or wireless connected? Pc is wired and the Switch is wireless
What other devices do you have connected to the orbi? Phone's, printer's, tv's, and directv
What is the size of your home? Sq Ft? 1400 sq ft
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected. I think around 50 feet or so
Any Wifi Neighbors near by? If so, how many? 14
What WPA security modes are you using? WPA2-PSK[AES]
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Ping
I would also try turning off all devices accept for the one PC or switch while gaming to see if pings are still high...Are there any other devices using the internet while gaming or just you gaming alone?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Ping
Yes 2 phones are connected during when I play my games I will try to disconnect the devices to see which one is the problem.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Ping
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Ping
I've heard of apps on phones causing increased ping times. Is it just one phone or do both have to be connected to increase the ping time?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Ping
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Ping
@fennypennyy wrote:
It’s only 1
My bet would be an app causing the issue if its one phone causing the problems. Not sure the best way to troubleshoot this other than uninstall individual apps, test, and reinstall if it doesn't fix the issue. The really hard part with that would be if it was more than a single app causing the problem. If there was 2 of the same phones, you could at least compare apps and that'd narrow it down to (hopefully) the apps that only the offending phone has by itself.
- Mark as New
- Bookmark
- Subscribe
- Permalink
