- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
I have an older house, circa 1950 with plaster walls. I have the RBR50 near the middle of our house. I am trying to setup the RSR50 satellite on the far side of one wall about 25 feet from the router. It does not get a good signal. On the near side of the wall about 20 feet from the router it's fine but then some devices at the far end of the house get really poor signal.
I have the basic default configuration with daisy-chain and MIMO enabled. I have read a few posts that suggest that turning one or both of these off may help though not sure exactly why.
The Orbi is in AP mode as my fiber modem is the router because of some network gear i have in the garage that is wired to that router.
Attached is my house - the grey lines near the top are the drop outs when the satellite is on the near side of the wall.
Any suggestions on how to improve range and performance are welcome.
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
@CordThomas wrote:
The status of the satellite is Good.
What tool would you recommend for a WiFi scan? I have Mac and iPhone. On the iPhone I have installed a few WiFi tools but none seem to give me a neighborhood scan.
My Mac's WiFi lists only about 6 other networks it can see. I live in a residential neighborhood without too many people living that close by.
Since you have a Mac you can use the native wifi analyser in MacOS as follows:
- Press Option key + Click on the Wi-Fi menu item in OS X
- Choose “Open Wireless Diagnostics”
- Go to the “Window” menu and choose “Scan” to immediately open the Wi-Fi Stumbler tool built into Mac OS X
- Within the Scanner tool, click on the Scan button to scan for available networks
- This will open the wireless card to detect all possible nearby wifi networks, effectively stumbling onto available wireless routers and discovering details about those networks.
My Setup | Internet Fiber ONT 250↓/250↑ | ISP Telenor | Wifi Router Orbi RBK50 AC3000, Router Mode, Wired Backhaul / Orbi RBK852 AX6000, Router Mode, Wireless Backhaul | Switches Netgear GS208 | Time Zone CET (Sweden)
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Re: Poor range between router and satellite - RBR50
What FW is currently loaded?
Is the Orbi system operating in Router or AP mode?
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials.
What WPA security modes are you using?
MIMO, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
Disney Circle: https://community.netgear.com/t5/Orbi/WARNING-Firmware-2-2-1-210-is-junk/m-p/1667485/highlight/true#...
If you updated to recent FW v.210, try enabling Daisy Chain. Some have mentioned that this seems to be working in reverse order, enabling means disabled actually.
RBK50 v2.7.2.104(WW) Circle Enabled
Additional NG HW: C7800/CM1100/CAX80/CM2000, Orbi CBK40, R7800, R7960P, EX7500/EX7700, XR450 and WNHDE111
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Turning off daisy chain made a dramatic improvement to throughput. With enabled, i was getting ~40 Mbps on devices connected to the satellite. With disabled, I am getting 500-600 Mbps...
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
So what is the status of the Satellite connection now as you see it in the GUI? Do you have a Good connection?
I think all you need to do now is to select the correct radio channels. Please make a wifi scan and see what channels are being used and choose the 2.4 and 5 GHz channels that are not or least used. This is for the client networks.
Unfortunately, for the backhaul networks you will not be able to select the channels but you can see in the wifi scan if the channel that you use is also being used by neighboring networks.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
When you disabled Daisy Chain, is the check mark removed from the box or check in the box?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
The checkbox is unchecked which I believe to be disabled. Since it is enabled by default (what i read online at least), it was checked to begin with and I unchecked it. I did see someone mention that with the latest firmware it might be reversed but that's not what it appears to be for me.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Thank you for the tip - works like a charm. I've had this Mac (a recovering Windows person) for over 5 years and did not know that existed.
It doesn't look like anyone else is on our channels - 2.4 GHz is 4 and 5 GHz is 48 - all clear it would appear.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Great. Then it's good to choose one of the non-overlapping 2.4 GHz channels: 1, 6 or 11 as fixed 2.4 GHz channel.
Good luck
