- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Poor signal on one satelite after uppdate to V2.2.1.210
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello got my new orbi yesterday working great.
When i wake upp today its been uppdating to V2.2.1.210
now i have poor signal on the closest satelite.
I been using orbi before one the same places using V2.1.4.16.
No problems on V2.1.4.16,is the orbi still auto uppdating?
if i go back to V2.1.4.16 it will uppdate its self to V2.2.1.210
the closest satelite is poor and the other satelite longer away is good.the satelites is connected to main router orbi,the satelites farway good but closest poor???
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Poor signal on one satelite after uppdate to V2.2.1.210
Try a power cycle OFF then back ON with the Orbi system?
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials.
If you updated to recent FW v.210, try enabling Daisy Chain. Some have mentioned that this seems to be working in reverse order, enabling means disabled actually.
https://community.netgear.com/t5/Orbi/Firmware-2-2-1-210-and-connection-problems-Skybell/m-p/1649275...
