Orbi WiFi 7 RBE973
Reply
Port 8080 blocked
drdoz
Apprentice
Port 8080 blocked
Tried to use a speed test website and it told me port 8080 was blocked.  Nothing in the Orbi configuration looks relevant to fixing this.
Model: RBK40| Orbi AC2200 WiFi System
Message 1 of 7
Guru
Re: Port 8080 blocked
What FW version are you using?
What browser are you using?
What is the Mfr and model# of the ISP Modem the Orbi is connected too? Built in router here by chance?
Wired or wirelessly connected when doing speed tests with a PC?
Message 2 of 7
drdoz
Apprentice
Thanks for the reply!
FW: 2.1.4.16
Browser: Safari
Netgear CM500 Modem has no built-in router
wireless succeeds, wired fails (weird)
Message 3 of 7
Guru
Same PC via wired? Try different wired PC?
Message 4 of 7
drdoz
Apprentice
wired or wireless, I can't connect to fast.com
also: appletv can't get netflix
computer also can't connect to netflix
wtf?
Message 5 of 7
drdoz
Apprentice
Fixed the Netflix, etc. stuff by turning off Circle.
Message 6 of 7
Guru
AH, Didn't know you had circle enabled. This could be the cause if not correctly configured. Smiley Frustrated
Message 7 of 7
Top Contributors
Discussion stats
  • 6 replies
  • 3994 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
