Discussion stats
  • 0 replies
  • 248 views
  • 0 kudos
  • 1 in conversation
Announcements
Top Contributors
Reply
Highlighted
Follower
Port Forwarding issue (tried all posted solutions)
Setup:
Modem (SB6141) to Orbi (RBR50)
Have DVR running on 192.168.1.169 port 8000
UPnP is disabled in Orbi, manually port forwarding port 8069 to internal LAN (192.168.1.169) port 8000
Port ForwardingPort Forwarding
When connected to the LAN, I can connect to my DVR so I can confirm that internal config is working.
Outside of the LAN, I can't connect. Also confirmed via http://www.canyouseeme.org/ that the port is closed. It takes a second or so, which tells me that most likely the port forwarding config is correct.
I'm not a newbie, since I've done this kinda setup before. Something weird about the ORBI.
Model: RBR50| Orbi AC3000 Tri-band WiFi (Router Only)
Message 1 of 1
