- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Powerline Satellite Magenta
hi guys, i have a Netgear RBK40 + Netgear RBS40.
everithing works fine until i try to add a powerline to the system.
when i plug a powerline to the satellite with the lan cable it works for 1 minute (more or less), i have connection.
after this minute, the satellite gets the magenta solid state color. connection lost and i have to disconnect the powerline from the satellite.
i did it for 5 times. it seems like the system doesn't allow me to add a powerline
can u help me?
thanks!
davide
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Re: Powerline Satellite Magenta
i had already seen this..
i need to understand why it is unable to obtain an IP address from your router or unable to your router after i plug the powerline..
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
magenta means your device is too FAR away
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
no, "Solid magenta. If your Orbi satellite ring is solid magenta, it is unable to obtain an IP address from your router or unable to your router."
this is why become magenta
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
@dagiam wrote:no, "Solid magenta. If your Orbi satellite ring is solid magenta, it is unable to obtain an IP address from your router or unable to your router."
YES
why not just move it closer and prove me wrong that its something else?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
i did it. but i doesn't depend from how far or close it is.
it happens only when i plug the powerline
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
You need to make sure the PL adapters are on the same IP address network as the RBR and RBS. Make sure the PL are working fully. These could be faulty.
Check the RBS with a LAN patch cable between the RBR while near or in the same room as the RBR to check the status. Should say wired.
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite
@dagiam wrote:hi guys, i have a Netgear RBK40 + Netgear RBS40.
can u help me?
thanks!
davide
RBK50 v2.7.2.104(WW) Circle Enabled
Additional NG HW: C7800/CM1100/CAX80/CM2000, Orbi CBK40, R7800, R7960P, EX7500/EX7700, XR450 and WNHDE111
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
ciao and thanks
last firmware. updated 3 days ago.
PL are old but they work.
i have the ORBI from more than 2 years. never had a problem. satellites are tin the same position as usual. so the distance is ok.
thanks!!
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
@dagiam wrote:when i plug a powerline to the satellite with the lan cable it works for 1 minute (more or less), i have connection.
I use Powerline to connect two Tivo units to my RBR50 router, specifically the TP-Link PA9020. Connected like this:
RBR50
to
8 port switch
to
Powerline
to
electric circuit----------------------------------------------------------------
to to
Tivo Tivo
Works fine. The Orbi has no idea there is a Powerline unit. All it sees is ethernet.
I have never connected Powerline to an Orbi satellite, but cannot imagine it would be any different.
Do you sync the Powerline units before connecting to the Orbi?
