Reply
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Preset Wifi ssid
- Mark as New
- Bookmark
- Subscribe
- Permalink
2018-12-16
02:38 PM
2018-12-16
02:38 PM
Preset Wifi ssid
Hi all, I've sucessfully setup my system and set my own ssid. Seems to work fine.W hen I look at all available wifi networks I see my new ssid and I still see the preset one (in my case orbi06). How do I fully disable the preset one?
Model: RBK50| Orbi AC3000 High-Performance Tri-Band WiFi System
Message 1 of 2
Labels:
- Mark as New
- Bookmark
- Subscribe
- Permalink
2018-12-16
02:41 PM
2018-12-16
02:41 PM
Re: Preset Wifi ssid
What FW is currently loaded?
After setting up the Orbi and satelite(s) the default SSID should disappear.
You sure you have everything setup and it's not a neighboring Orbi wifi?
Power OFF the system for 1 minute, then turn on the router and check the SSID. Then power on a Satellite and check the SSID.
Message 2 of 2
Announcements
