Orbi WiFi 7 RBE973
Reply
Problem Updating FIrmware RBR20
MarkD1944
I got an email today from Netgear that indicates that there is a firmware update for  my router to V2.3.5.36.  I currently have V2.3.5.26.  When i go to update the router says there is no update.
So, I tried to manually update the firmware by downloading the update and using the 'Manual Update' option.  However, it asks me for my password again and it does not accept the password.  I have rebooted the router a few times to no avail.  Any ideas out there??
Thanks, Mark D
Model: RBR20|Orbi AC2200 Tri-band WiFi Router
Message 1 of 14
Accepted Solutions
MarkD1944
Re: Problem Updating FIrmware RBR20
Just for grins I tried it againj today.  The update worked fine -- I'm updated to version .30
I suspect that there was something wrong with the versioning at Netgear, but really I do not care as it seems to be resolved.
Message 14 of 14
All Replies
echo92626
Star
I have the same problem in trying to update the firmware last week. It will not show in the router app nor website.
Yet today I get an email there is an update and still cannot update automatically update.
As far as a manual website option, I did manage to get the Satellite to update but never the Router.
Keep in mind, you'll probably have 2 passwords: one for the Router and one for your Netgear Website login, might this be the problem?
BTW, ANYONE AT NETGEAR ABLE TO LOOK INTO THIS??? With the 90 DAY support option, it leaves those at 6 months without the ability to get official support.
Message 2 of 14
Guru
@MarkD1944 @echo92626
You can manually download v36 from here:
 https://www.netgear.com/support/product/RBK20.aspx#download
If you do, use a wired PC, web browser, IE11 or FF, and unpack the .zip files. Update the RBS first then RBR lastly.
If your systems are working with out any problems, you can keep whats loaded. "if it works, don't fix it!"
Message 3 of 14
MarkD1944
That is not the problem.  I was able to download the update, but when I tried to implement the 'Manual Update' the software would not allow me to get past the next username/password.  It was the correct name/password, same as that that I logged in with.
Message 4 of 14
Guru
Reboot the RBR. Clear all browser caches. Exit then relaunch the browser. Try a different browser. After the RBR has rebooted, log in and go into immeditally to try to update the FW using the web browser on your wired PC.
Message 5 of 14
MarkD1944
DId all that with same result.  I guess I'll continue with existing firmware.
Message 6 of 14
Guru
Might contact a forum moderator to see if there is any information regarding this. The FW should be working and applying.
@Blanca_O
Message 7 of 14
echo92626
Star
Thanks, Just sent Blanca an email.
@Blanca_O
Message 8 of 14
Retired_Member
Not applicable
Thanks, Mark D
Why do you feel the need to update???
Message 9 of 14
MarkD1944
Well, it is allegedly a security update.
But I should be able to update whenever a new update occurs.
Mark D
Message 10 of 14
Retired_Member
Not applicable
Mark D
IF it was something crtical to your system, NG would push it with no action on your part.  All others are at users risk.
Message 11 of 14
Guru
Sounds good. Ya, if it's a security patch, its something that needs to be checked to ensure users can apply it. Security needs to be applied when avaiailable. Most security patches are manual updates. Let us know how it goes.
@Blanca_O
Message 12 of 14
Retired_Member
Not applicable
not true
Message 13 of 14
MarkD1944
Message 14 of 14
Top Contributors
Discussion stats
  • 13 replies
  • 2628 views
  • 1 kudo
  • 4 in conversation
Announcements
Orbi WiFi 7
