- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Problem with Wifi on all Apple Devices on my Network
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Hi all,
I was wondering if anyone else had any experience with not being able to access a device that's currently connected to a different satellite. For example, if I was on my laptop in my basement, which was connected to the basement satellite, and my wife was on her laptop on the 2nd floor and that device was connected to the 2nd floor satellite, I can see the device on Finder in Mac, but I am unable to access it. When I Ping the IP address it times out. When I bring the devices together in the same location so that they're connected to the same satellite, it works fine.
Any ideas for a workaround?
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Is Daisy Chain and Fast Roaming enabled? Might disable these and test. Roaming will be a client device behavior as well.
The first wave to be released are only for the RBR50 and RBS50, which is used in the RBK50 and RBK53 (Costco) kits.
New beta FW avaialble. Get it while its hot of the press:
https://community.netgear.com/t5/Orbi/Orbi-MR-2-1-Update-3-23-18/m-p/1533584#M26234
My Setup | ISP SparkLight | Internet Cable 1000↓/50↑ CM2000 Modem | Wifi Router RAXE50 and R8500(v.158) Router Mode and RBK752(v.2) AP mode | Switches NG GS105/8 |
Additional NG HW: C7800/CAX80/CM1100/CM1200/CM2000, Orbi: CBK40, CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: R7000, R7800, R7960P, R8000, R8500, RAXE500, RAX50, XR450, EX7500/EX7700, GS308v3
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Re: Problem with Wifi on all Apple Devices on my Network
I had Daisy Chaining off by default, but Fast Roaming was on.
After disabling that, from tentative early tests, I am able to ping different devices connected to a different satellite. Thanks for your input!
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Enjoy.
